Number of Channels - Help
Username: Jryevols
Little rock, Arkansas USA
Post Number: 30
I have noticed when I go to Lyngsat to check channels that there are are great deal on both 110 and 119. I am getting justa little over 200 on one and less than 200 on the other. Can anyone tell me the number of stations that I should be getting and why I am not getting them all. Is the strength of the signal 80/70 Please help me understand. I see a great deal of channels that I am not getting.}}
Username: Runnerguy
Pluto
Post Number: 624
598 approx
Username: Runnerguy
Pluto
Post Number: 625
check you settings and signal strength, loose wires, switch etc
Username: Crazy_greek
Post Number: 1167
sat-man
Try a TP Scan.
If some of the TPs have no Quality Signal or
below 50% you will need to adjust your Dish.
Username: Lklives
Post Number: 12328
The number will vary based on your location, and strength of ALL TP signals from there....
