Viewsat ultra question
Username: Noahjosh
hello first time here and quite new to this..
Just bought an ultra..I have a dish capturing both dish net and bev...how do i program this ultra to read all both sats?
do i just upload the both bins for both sats..then switch from sat to sat when needed?
any help is much appreciated
thanks
Username: Lklives
Post Number: 12386
Its 1 bin that has BOTH Bev and DN nagravion 2 decrytpted...so upload 1 bin, and then do the other necessary things to the receiver..
Username: Hawaiian_time
Kanaka freak...
Post Number: 1512
It would be easier for you to go to total-fta.c0m. They are the viewsat official site and have all the information that you might need. You just need to register.
Username: Tapeman
New York City in-HD, NY
Post Number: 1516
- 1 Bin will work for both 070911U
- Yo have to set each LNB in antenna setup
- 1 LNB for each satellite for example (82/91 and 110/119) yo'll need 4 LNBs (2 dishes and 1 DISEqC) which usually comes with unit
- goto http://satcalculator.freehostia.com/
- Find exact pointing angle and elevation
- Azmith means locate true north and start counting clockwise
- Turn your beep option on your Ultra to avoid using Sat finder or simply use both
- Always look at top right corner to read Satellite orbit location in your antenna setup
- Make sure your Receiver unit is always off when wiring coaxial cables and switches
- Assign each LNB to 1 unique DISEqC port
- Scan one satellite at a time
- Ask questions yo'll learn more
- Read often
- Check King's corner for proper wirring
https://www.ecoustics.com/cgi-bin/bbs/show.pl?tpc=2&post=1080851#POST1080851
Username: Noahjosh
you guys are great
thanks
Username: Donnie1973
Post Number: 994
good post King
