2500 to2700 bug report on 211 bin for flu
Username: Jfk
Post Number: 21
I'm losing signal on some channels.
Username: Lklives
Post Number: 11939
thats NOT a bin issue...thats a scan or hardware issue
Username: Viruscauser
Leesburg, Georgia
Post Number: 230
Houston, we have a problem: Three or more version 211 modified bins for the converted 2500 boxes came out just today. It would be helpful if problems reported came with the full name of the modified 211 bin that was used.
Username: Jfk
Post Number: 22
jvvh
Leesburg, Georgia
Post Number: 231
=sigh=: Full name John Doe. jvvh came out with 211_pwT and then he came up with 211_pwTd where the "d" stands for solving Diseqc problems that the first bin was giving.
Which one did you use?
Username: Jfk
Post Number: 23
211_pwtd
Leesburg, Georgia
Post Number: 232
That's the one I'm using since about 9:30pm yesterday. No problems yet (fingers crossed).
Username: Horaceec
Long Island Bahamas
Post Number: 50
hi every one i have a pansat 2500 converted into 2700 .i dont know which file to use can someone help and tell me what site to go to for the bin tell me if i should use clone or genuine bin please help me .thanks in advance
Username: Fufamc
Nashville, TN Devitson
I did the 211 and my reciver died.... Dose anybody know how to bring it back? HElp
Username: Lklives
Post Number: 11956
give it CPR and mail a check to DN and BEV
Username: Shadow45
Monterrey, Nuevo Leon Mexico
Post Number: 61
For clones you have to use the jvvh211_pwdt bin...good luck reviving your receiver dude
Username: Lklives
Post Number: 11959
Clones do NOT use jvvh 211 bin...CONVERTED 2500 receivers do...
Clones use bin 211v1 w tivo
Username: Fufamc
thanks
Username: Booboo123
how can you convert pansat 2500 to a 2700
Username: Cable
Post Number: 90
ok the problem is you have to use the disek port 3 enen though you are not using any disek... just change it to the disek port 3 and it will work thats what i did in mine i used to have a same problem too loosing the signal....
so just change it to deisek port 3 it will work for you
