VIEWSAT EXTREME ISSUE HELP
Username: Unluck
Windsor, Ontario Canada
Post Number: 8
I am having a problem with my viewsat. I was away all night and it was on. I just loaded the new program and all I have is 4 dotted lines in the front. No on or channels or anything. What happened to me?
Username: Donnie1973
Post Number: 1111
factory reset it and try again. make sure u are using the extream file.
Post Number: 1112
u may need to load it with a factory bin first.
Username: Unluck
Post Number: 9
I just did a factory reset and now it says FAIL
Post Number: 1119
out in a factory bin from totalfta or ftaprosupport. Then reload latest bin over that
Username: Unluck
Post Number: 10
I just loaded another program and it says " END " I powered off and turned on and I have my 4 dotted lines again.
Username: Unluck
Post Number: 11
I loaded the latest factory from ftasupport and then the latest bin and I get the same thing....
Post Number: 1120
what will it do if u just load the factory bin on it and try to watch tv?? I know u wont get everything but u can see if it works at all. Might be a bad bin file.
Username: Unluck
Post Number: 12
I have 2 identical receivers and my other one works great with that file. I am getting nothing at all. It's not even allowing me to get into the receiver to load channels.
Post Number: 1123
I would put the factory bin on it and see what u get.
Username: Unluck
Post Number: 13
I keep doing that and it keeps coming back "FAIL"
Post Number: 1124
thereis a post at total called "bring your reviever back from the dead" maybe read that.
At least u have lights and it is responsive somewhat.
Username: Unluck
Post Number: 14
I just tried it out and I get a black screen. Nothing has changed.
Post Number: 1125
same readout on the front??
Username: Lklives
Post Number: 12774
If it says FAIL...then its NOT dead!...its a cable or comport issue...or bad timing in upload...be persistent and force upload the factory bin!
