Can't get Dtime and national geographic channel
Username: Loverboyz
Post Number: 24
I am pointing to dish 110 and 119 using pansat 3500. I get most of all the channels including ppv. But somehow i can't get DTime and national geo. When i scan i get Dtime but when i go to that channel i get no signal.
One thing I noticed is when I tried scanning frequency 12341 on transponder 9 and frequency 12370 transponder 11 I don't get any of these channels. I tried moving my dish but still can't get it. Is there some other way to check.
Thank your
Username: Lklives
Post Number: 11811
do a TP scan of those ..
Username: Viruscauser
Leesburg, Georgia
Post Number: 194
It's also possible that your switch, not your dish could be the problem.
john, give this a shot: DTIME is on Echo 8 so try, if you can, to scan that TP after connecting the dish directly to your box WITHOUT going through the switch.
If it works that way, you probably need a new switch.
ALWAYS POWER OFF THE BOX WHEN MESSING AROUND WITH THE CABLES.
