Three Viewsat Ultra receivers connected thru DP34 to DP Digital LNBF 61.5, and DP TWIN LNBF for 110, 119
Username: Bp46
I am a novice. I have connected three viewsat ultra ( thru Diseq switch...using port 3 connceted to dp34 ) at the 3 output ports of DP34. The inputs to the DP34 are: Port 3 DP Digital LNBF pointing 61.5; Port 1 and 2 from DP Twin LNB pointing 110 and 119.
I was only able to scan a number of channels from 61.5 by disconnecting the 110, 119 inputs.
When all port are connected on DP34, only when I reconnect to port 1 of diseq I can get all channels but doing so I do not get a number of channels on 61.5.
Can any one help
Username: Lklives
Post Number: 11751
First remove all switches and run 1 cable fron each LNB directly to each receiver and do F1 scans to ensure u are alignede at sats correctly...
next...use ONLY a DP34 switch ONLY....no disque switches needed..
NEXT
run the DP 61.5 to port #4
run the DP Twin with 2 cables ...119 to port #1...110 to port #2
run 3 cables from 3 outputs on DP34 switch to the 3 ultra receivers
now go into each receiver and configure the antenna/dish/LNB and switch port settings to same as above
watch TV
BTW...61.5 does NOT have many channels..compared to 110 and 119...
