DN 1000.2 dish with 4 LNBs
Username: Scorp7
Post Number: 39
Hello experts, Understand DN is now a days installing new 1000.2 dish with 4 LNBs so that it can take four satellites - 110/119/118 and 129. Are FTAs compatible with the LNBs?
I think you may need a power source with FTAs if the LNBs are compatible. Any more info highly appreciated. Thanks
Username: Tapeman
New York City in-HD, NY
Post Number: 1295
110/119/129 standard Circular DSS LNBs
118.75 Circular FSS LNBs uses lower frequency
Also many channels on 129 started to use MPEG-4 with 8PSK
110/119 your best choice at present time
Username: Satscanner
Beaversbush, Sportsmans P... Great White ...
Post Number: 2912
Yes, they are capabal.
Post Number: 2913
meg 4 chn's excluded.
Username: Scorp7
Post Number: 40
Thanks for the info. Is it true that DN moving or mirroring all Internationals to 118 so that all programs can be recieved using only one dish unlike current situation where you need separate dish for 61.5W on the east coast? Thanks
Post Number: 2916
check lynsat for the latest info on that.
http://www.lyngsatt.com/
remove one t
Username: Careyc
what do i need to do to switch from bev to dishnet on my receiver
