Key Code Change Ariza Receivers Help How To Guide
Username: Themangod
Post Number: 169
Key Code Change Ariza Receivers Help How To Guide for changing satellite dish bev and dish key codes.
For new working key codes always have a good simple to use key grabber that has working keys. [link removed] Is a great satellite dish key grabber that always has working keys for the times when fta websites are busy or you just need them quick.
Ariza:
Code:
1. Press Green button
2. Press Red button
3. Press Red button
4. Press Menu button
5. Press right arrow several times until you see nagravision.
6. Now depending on the key that changed and is active you must scroll down til
proper key to be changed.
Example: On 06/09/05 ECM key 01 is active. Scroll down to provider 000101 key
line 01 and enter xx xx xx xx xx xx xx xx (enter number with your # button in your
remote and for letter follow code definition button on your TV screen)
7. Press OK for 5 seconds.
8. Exit, exit ...........
9. Change channel and watch TV.
for key codes go to [link removed]
Username: Themangod
Post Number: 170
make sure you do number 7 right other wise it wont save and you will have wasted your time.
