New Viewsat Bins out
Username: Hawaiian_time
Kanaka freak...
Post Number: 1302
Don't know if anyone mentioned it earlier but Total has new bins for all viewsats.
Kanaka freak...
Post Number: 1303
Sonicview also has new bins out at this time.
Username: Brucester
Post Number: 509
do not forget the cw600p came out at around 9;50 last night keep up the good work cw and team
Username: Micklee11801
Post Number: 126
What's happen to future-fta site? Very time try to go there, it say " not found". Are we going to get new bin on pansat?
Username: Frobi
Guelph, Ontario Canada
Post Number: 51
Is this the new bin for CW600 premium?
CW600SV1.37_ARFix ?
Some one on another poast said its 145AR.
Username: Brucester
Post Number: 511
for the cw600p it is 145 for the cw600s it is 137 do not put the rong bin in or box will be no good
Username: Nydas
Post Number: 3288
Both the future-fta and the totalfta sites are revamped and extremely easy to get to for new downloads.
http://www.totalfta.com
Latest News: August 17, 2007 3:55am EST
New files for the following receivers:
Viewsat Extreme
Viewsat Platinum
Viewsat Ultra
Viewsat Pro
Sonicview SV1000
Sonicview SV4000
Sonicview PVR1000
Sonicview 8000HD
Entrance page has been added to the site to give a quick reference in case of forum overload. Links to updated files will be posted here for quick retrieval by all members instead of having to fight the forums.
Username: Hi09
Post Number: 11
would someone be kind enough to help a rookie, 2 qyuestions:
1. WHat is the purpose of upgrading the BIN - is it so that when a key goes bad, we dont have to keep manually entering new ones?
2. Can someone tell me how to install new bins - i have a viewsat Extreme - and i got the Cable to connect to my PC as well?
Username: Nydas
Post Number: 3299
Adam: Answer to no 1 is "yes"
To upgrade the BIN, you must download the new BIN out today at
Also download the loader for it from the Viewsat extreme section, and GET THE INSTRUCTIONS.
Unzip the files before starting.
Follow the instructions.
Username: Cartier1
Post Number: 590
nalin thanx . do u know if c*oo*lsat5000 is out could not find it . thanx
Username: Pedestrian6
Is anyone having problems with Viewsat ultra even after input of new bin? I loaded the bin, at first it would not do autoroll for me. Then i reloaded it and it finally started autoroll, its been 'rollin' for about 1hr with nothing. I have BEV, and even imputing keys and turning autoroll off didn't work. Any advice? new keys? newer bin?
Bin i am using is 070817
Ignore post above. Seems like autoroll for about 2hrs fixed it ;)
