All of a sudden today my Pansat 2700 is displaying video that is shaking horizontally and I can barely make out the text on the screen. Ive tried disconnecting everything ans reconnecting and as well as unplugging it from the wall for 15 minutes but none of this worked. I have b75 loaded on there. Any ideas on what is causing this?
Check the tiny rear channel 3 /4 output switch between the lnb and tv ant coax outputs .Make sure it's on ch 3.You might have unintensionally changed it hooking up the connections.Also check your tv settings and menu settings in the receiver menu to be correct for ntsc ,and check if the problem persists using rca outputs.
i have my 2700a upgraded to b75 loaded latest bin 205 it worked for while and few channles only now its showing no signal on screen and when i try to blind scan it shows 0 transponder found there is no signal at all can any one hlep help me please
