Keys Viewsat 2000 Extreme Key Code How To Enter
Username: Themangod
Post Number: 157
Viewsat 2000 Extreme Key Codes And How To Enter Key codes
Here is a simple to use Working key code grabber for keys.
[link removed]
How To Enter Key Code Viewsat 2000 Extreme
Code:
1. With unit on hit them MENU button on remote.
2. Scroll down to User Settings hit OK button on remote.
3. Now scroll down to "Code" and hit the "OK" button.
4. Next scroll down to "Nagra" and hit the "OK" button.
5. On the next screen, hit the left arrow to get to the key window for the provider
you need. Make sure you go to the second one of that provider. If you don't see 5
lines of code (for Dish Net,) then you need to hit the left arrow again. Dish
Provider ID is "Dish Net 010100," and OFF LIMITS Provider ID is "OFF LIMITS 090100.
6. Now skip the first line of code. Do not alter this line. (For Dish Net Only)
7. On the second line, it should start with 08. Using the right arrow, move to the next
set of digits. You will always want to leave the first 2 numbers there. They
identify the line.
8. Enter the first half of Key 86 (Key 00) into line 08.
9. Next enter the second half of Key 86 (Key 00) into line 09.
10. Then enter the first half of Key 96 (Key 01) into line 88.
11. Then enter the second half of Key 96 (Key 01) into line 89.
12. Remember, DO NOT ALTER THE FIRST 2 DIGITS OF ANY OF THESE
LINES. Start with the second set on each line.
13. Now hit the "Exit" button.
14. Highlight "Yes" and hit OK.
15. Exit out of the menu, and change the channel.
16. Watch TV.
Buttons may differ for some recs. Here are the buttons for the letters.
A = F1 (Red button)
B = F2 (Green button)
C = F3 (Yellow button)
D = F4 (Blue button)}
Username: Themangod
Post Number: 158
make sure you turn off autoroll then turn off the receiver by the back of the unit then after 1 min turn it back on and then enter the keys how it says to above.
Username: Vanillaface25
Hi i understand most of this but what i dont get is dat wen i go to my dish code page i dont see key 96 all i see r 5 rows with 9 columns and da 5 rows start in this order 00 08 08 88 and 89 im stuck on steps 10 and 11 because i cannto find key 96 or line 01
