Help With Viewsat
Username: Jrpistonsfan
Post Number: 51
I have two Viewsat Ultras. The first one gets all the channels perfectly. The second one only gets about half.. They are connected to one sattelite with two LNB's on it.. Is this a problem with the receiver or the satellite?
Username: Donnie1973
Post Number: 636
Are all set up setings the exact same on the one that doesnt work as the one that does? Swap the two out to see if the problem follows the cable or reciever.
