Viewsat Extreme Where are the experts?
Username: Vova_putin
Post Number: 24
I can't load the new bin, everytime I try, no matter, unit on first, wait 2 seconds, turn on,unit off start pgm unit on..... several different ways listed in site, but not one works. Keep getting resending but never loads. None of our experts have a clue how to get this thing to load?
Username: Satscanner
Beaversbush, Sportsmans P... Great White ...
Post Number: 2541
Are you using a straight or null modem cable ? You need a null modem cable, #2 and #3 terminals are reversed as compared to a straight cable.
Username: Guanajuatos_best
Post Number: 21
PLEASE EXPLAIN HOW YOU ARE TRYING TO LOAD THE BIN
STEP BY STEP
THAT WAY WE CAN SEE WHAT YOU ARE DOING WRONG
Post Number: 25
What is really strange, this is the same null modem cable that came with the VS, used it before and loaded no problem. Now it won't work. Is it possible that something in the STB needs to be changed? Still using bin from 12-20-06. Looked to see if maybe there was an upgrade on off option. Can't find anything.
Post Number: 22
Extreme File: http://www.totalfta.com/DBPSW-070801X.zip
Platinum File: http://www.totalfta.com/DBPSW-070801P.zip
Ultra File: http://www.totalfta.com/PFTAUSW-070801U.zip
Pro File: http://www.totalfta.com/VSPRO-070801A.zip
PVR File: http://www.totalfta.com/PVRSW_070801A.zip
Post Number: 26
Tried several different, most common, VS off, start loader 2, open file, PC>stb, VS on in back.
also tried VS on at outlet, also tried with VS on start program> switch off> 2 seconds> switch on. (found last on DSSTESTER)
Post Number: 27
I have the Extreme, I have the 070801X file, just can't get the thing to anything as far as loading...
really strange.
Post Number: 23
FIRST DOWNLOAD BIN
THEN SAVE IT ON FOLDER
THEN RIGHT CLICK AND SELECT EXTRACT FILES
THEN SAVE ON FOLDER
OPEN LOADER 2
CLICK OPEN
FIND FOLDER WITH SAVED BIN
SELECT EXTRACTED FILE
TURN OFF VIEWSAT BOX(WITH BEHIND SWITH)
CLICK : (PC TO STB)
WAIT TWO SECONDS
TURN ON BOX (WITH BEHIND SWITH)
AND IT SHOULD BE IT!!!!!
Post Number: 2546
Way to go paisa! stick around ,your a good asset here.We need more ppl like you .
Post Number: 28
That's not doing it either....
It's not loading at all.
Sending ZRQINIT then resending......
Nada
Post Number: 26
THAT IS WEIRD
Post Number: 2547
do you have the correct com port and setting on your pc?
Post Number: 27
WHEN YOU SELECT THE BIN WHERE IN LOADER2 DOES IT APPEAR?
Post Number: 28
WHICH LINE?
Post Number: 29
Com 1 checked device manager to make sure, tried different baud rates..... Right now, I'm guessing, if nothing in the box is changeable, the cable may be bad. Something may have happened to it since December.....
Post Number: 30
Bin goes in irst line.
Post Number: 31
'first'
Post Number: 29
THEN IT SHOULD BE YOUR CABLE
Post Number: 32
Hanging head here.... going to get new cable...
Post Number: 33
Thanks much!!
Post Number: 2548
Get a quality one. The ones that come with the receiver are as cheap as they get,with scrawny thin cable .Shorter is better too ,and preferably with magnet interfearance suppression. about 9 dollars.
Username: Curse429
Paisa, can u send me the loader 2 file or post it here ?
