ExtremeView Magum bin
Username: Micklee11801
Post Number: 121
Hi,
Does anyone know when we will have bin? A lot of the boxes already have it. How much longer we have to wait or where can I get it? Thanks
Username: Runnerguy
Pluto
Post Number: 438
v 152 Magnun bin is out!! http://www.satjunkie*com
(.for*)
Post Number: 122
Hey Zulu,
This site is not working. Any other site to get the bin for Magnum.
Username: Lucky88
San Antonio, Trexas USA
hey does anybody have bin files for cs5000???
Username: Runnerguy
Pluto
Post Number: 450
Anybody having any luck with Autoroll with new TR v 152 bin for Magnum?
Username: Lroy
Post Number: 239
All c00lsat files are at [link removed]
Username: Runnerguy
Pluto
Post Number: 451
Blow Me!! lroy tipit with your grafitti scam spam.
Username: Runnerguy
Pluto
Post Number: 452
Answer my own question concerning Magnum:
C/P from thebroken
Team Reliable Coder
Please READ before loading 152...
Ok, I notice some people dont like to read other's experiences before loading a bin, SO, I will give you an update.
THIS BIN was never meant to be released...
It was a fall through, meant to give you guys autoroll, and NO MORE than that.
The code base has been through some dramatic core changes, and as a result it is COMPLETELY different from any other bin released to date. Database (FOR CHANNEL STORAGE) has been moved to the FLASH (So channel list wont disappear when you decide to go on vacation) Scanning core has been rewritten completely. Kernel is based on newer coding techniques.
I did not get a chance to convey all the details to Mikesmadd before releasing, and we were rushed to get this out before it was ready.
SO
FACTORY DEFAULT BEFORE FLASHING THE FILE
FACTORY DEFAULT AFTER FLASHING THE FILE
The reason is simple
THE CHANNEL LIST IS NO LONGER STORED IN THE SAME LOCATION
Also, before this bin you had a maximum of 3500 channels (2000 TV, 1500 Radio).
NOW, there is a limit of 8000 channels (6000 TV, 2000 Radio)
Channel Master WILL NOT WORK for the time being, because it does not support LZW compression, which is used in this codeset to allow for faster interaction with the FLASH, and to allow MORE data to be stored on the flash.
We will be submitting information to C-Sharp to resolve the channel list incompatibility.
People saying that it is freezing, I understand your concern, please, turn off autoroll after you have rolled the keys.
Bev users, in 153 you will have the ability to retrieve 7 day guide for BEV, with a second LNB pointed at 82.
__________________
Username: Franktodd
Post Number: 31
where would someone find these bins?
Username: Runnerguy
Pluto
Post Number: 460
Future FTA - Blacklist's Site:
[link removed] (C00LSAT and All receivers)
DSS Newbies:
[link removed] (Pantecs,all clones and all receivers)
File Share Site - No Registration Required:
Good for gettting Original factory firmware:
[link removed]
Best site for DISHNET info, channels, transponders and changes etc..
[link removed]
[link removed]
www.filez.us/km3/keys.shtml
Username: Runnerguy
Pluto
Post Number: 463
Magnum roll with TR v152 bin when you reset and rescan.............For those of you who are to lazy to do that try this:
C&P from SatJunkie:
when we have to enter the keys manually this is what I do.
Rather then get up and off the couch, I go to MENU>SOFT CAM> and I change the provider name to GlobeCast and if that don't work I change it to DIGITAL+ wait for literally 5 seconds and BAM TV back on!
Username: Curse429
can anyone peovide the viewsat laoder 2 file
