Key Ripper type program
Username: Lynchmob450
Post Number: 70
Can someone direct me to a site that i can download a Key Ripper type program? Someone had previously mentioned Key Master...but i couldn't find a site that had a free download for this program.
Thnx in advance for your help!
Username: Nydas
Post Number: 3147
[link removed]
Username: Lklives
Post Number: 10680
U can get KeyRipper aka VS keys program for the Viewsat and Coo*lsat at www.totalfta.com ...keymaster 4.0 is most likely there also..
Post Number: 71
Thnx Nalin & LK!
Username: Lklives
Post Number: 10685
here's keymaster 4.0
http://www.ftaprosupport.com/forums/showthread.php?t=3303
Username: Kingkes
Lk I need Your help with getting my viewsat extreme back online please.IThis is my first blackout and I am Really dumb where this is concerned.
Username: Lklives
Post Number: 10686
Viewsat Step By Step Flashing Instructions & More
PLEASE DO NOT PM ME WITH QUESTIONS, POST YOUR QUESTION IN A NEW THREAD IN THE DISCUSSION FORUMS HERE.
If this is a new STB/receiver you should get at least two files before you start.
LOADER2.ZIP (viewsat utility section )
An up to date latest file, found in the Viewsat Files (fixs and updates) section here
Use only Platinum PGM files on Platinum or Lite
Extreme PGM files are for Extreme only
HOW TO FLASH.
You can flash (load) your receiver with a bin on top of the bin (file) you already have. It will replace it.
Use a Nul CABLE RS232 on your receiver from the computer. Or use a Nul adaptor from Radio Shack number 26-264B to make a straight through cable a Nul cable. Take the cable off going to the LNB to be safe. If you don't have a 9 pin plug on your computer you may need to use a USB to Serial cable 26-183 at Radio Shack.
Un-zip all the files and hook up the cable from your computer to the STB, keep the STB off with the switch in the back. Start the loader-2 and click on OPEN FILES. Find the bin file you un-zipped that now ends in PGM. Click on it and it will automatically go on the first line of the loader. Click on the icon just below the word TOOL and check the COM PORT. Then turn STB on from the back and at first light click PC->STB on the loader. If the progress bar don't move after about a minute start over again. Sometimes the timing is critical. Even try turning STB on from the back first then click PC->STB. Don't do anything as the progress bar is going across. Make sure the Computer & STB are done before you go to the next step. They may not get done at the same time.
When file transfer is completed, the Front Panel will display:
"inst" for 15 seconds while the software is being installed
"DONE" for 10 seconds while the ViewSat does housekeeping chores
Next, the ViewSat automatically REBOOTs
" on " will be displayed and when the reboot is complete, "0000"
You may NOW turn "OFF" the ViewSat and connect it to your TV and satellite dish cable
Some problems occur from users not waiting long enough after flashing. The unit now has an extra step involved. When finished it will say END, then 0000, then boot, then END, then back to last channel or 0000. You must wait till this process finishes before unplugging. Unplugging while it is finishing causes the unit to fail
PLUGGING IN CABLE.
Make sure you plug in the cable from the dish to the receiver at the LNB 13/18v INPUT. Not the ANT IN. The cables coming from the dish to the switch should be put on the switch at the same number as you have set in your receiver. "Example", 119 cable goes on number 1 on the diseqc switch and the receiver has #1 for 119 in the program. You can only get one Satellite for each one LNB you have. Two LNB's two Satellites, and so on.
Now you will need to set your settings. Below is what most have.
MENU, INSTALLATION, then 0000 or 0937 or 2668 or 3570 then ANTENNA SETUP then side arrow to ECHOSTAR 7 119.0W check your Satellite setting. Then do the same to ECHOSTAR 8,10 110.0W
EchoStar 7 - 119. ECHO 7
LNB Power------ON
LNB Type-------Standard For dish pro set to OCS
LNB Freq-----------11250
22kHz-------------Off unless you have a 22kHz switch turn on.
TP Freq----------12339
Search option-----All
DiSEqC 1.0------Port 1
Motor--------------Off
Legacy SW------None
HIGHLIGHT any line EXCEPT Top "SATELLITE 119.0W" line
F1 to REGULAR scan the 110 TP's
When finished,
"EXIT" and "YES" to Save.
Go to next Sat to scan
EchoStar 8,10 - 110.0W May also say Echostar 6,8
LNB Power------ON
LNB Type-------Standard For Dish pro set to OCS
TP Freq----------12224
DiSEqC 1.0------Port 2
Legacy SW------None
HIGHLIGHT any line EXCEPT Top "SATELLITE 110.0W" line
When finished,
Satellite: Nimiq 1,3 91.0W
LNB Power------ON
LNB Type-------Standard For dish Pro set to OCS
22kHz-------------OFF you can't use a 22kHz switch with more then two Satellites.
DiSEqC 1.0------Port 3
Legacy SW------None
HIGHLIGHT any line EXCEPT Top "SATELLITE 91.0W" line
F1 to REGULAR scan the 91 TP's
THIS IS WHAT MY SETTINGS ARE. You can start here then change them later.
MENU, OPTIONS
Close Caption---------OFF
Sort by SID-------------ON
AUTO TP---------------ON
AUTO ROLL-----------ON
EPG Hours-------------24
Full Channel Name--ON
Now exit out to Channel and wait for keys to roll may take up to 15 minutes leave on 1 channel
Installation, Parental Control
Receiver lock Off
Menu Lock ON
Information timeout 3
Maturity Rate Unblocked
Change PIN Code ????
MENU, SYSTEM SETTINGS
System Settings----Letter Box
Screen Type--------------63
Menu Language-------English
Audio Language------English
Channel Mode---------Normal
HOW TO DO A FACTORY DEFAULT
MENU, INSTALLATION
When you do this you will also clean out your channels.
How To Enter Keys Manually In Your Xtream.
1. Menu
2.Installation
3.Enter Pin 0000
4.Code
5.Nagra
6.Left until you see what ever Satellite you want.
Put 00 keys on line 08 & 09 don't change the 08 or 09 number
Put 01 keys on line 88 & 89 don't change the 88 or 89 number
EXIT once then OK to save, the light color is the one you pick to save then EXIT out.
HOW TO SEARCH/EDIT, ANTENNA CONFIGURATION, ADD SATELLITE, RENAME SATELLITE, DELETE SATELLITE.
MENU, INSTALLATION, 0000, SIDE ARROW TO DN OR BEV, then down once to NETWORK SEARCH ON, Then down once to HAMMER ICON then side arrow to what you want to do.
ADD A TP
To add a TP go to the channel scan section, select Dish or Nimiq 1,3, go down to the green screw driver and hammer icon, hit ok to enter the tp list, then F1 button to add new TP You can also hit the pause button in this section to get a overview of other actions.
HOW TO TURN AUTO-ROLL OFF & ON
MENU,OPTIONS then go to AUTO-ROLL
SET GMC TIME
MENU, INSTALLATION, TIME SETTING. Set to - 5:00 for east coast
RESET RECEIVER
Sometimes you need to do a reset, (hard boot). Turn power off then on from the back.
Edit/Delete Message
