2700a not downloading, remains at 0%
Username: Mafri
I posted just before, that my pansat is not responding. How can y flash him?
Username: F_t_a_is_back
Post Number: 226
What do u mean it is not responding?
Username: Donnie1973
Post Number: 630
If it is not downloading, ur antanna set up is prolly wrong
Username: Jockster
Brampton, Ontario Canada
hey i kinda had the same problem...i tried to dl the bin file and it stayed at o% then a window popped up saying FLASH UPDATE FAIL...
Username: Jockster
ne1 know how to enter the keys in the pansat 2700a manually?
Username: Mafri
Post Number: 7
Hallo, i resolved my problem by downloading the original pansat bin and then installing the other one . it functioned!Thanks to all
Username: Jockster
hey mario can u tell me where u got the bin files from
Username: Abdou91
514
Post Number: 82
what cable are using is yr 2700 genuime or clone? give more info
Username: Dude123
Post Number: 1063
jawad
you just gotta do a bit of reading there are alot of sites wehre they have how to guides posted and alot of sites where you can get loaders bin files and all other files if you want to enter the kays manually and you have genuine pansat 2700 just enter 8282 using your remote and go to nagra vission 2 to enter keys
Username: Jimel143
need the new keys...can nayone help
Username: Albino_midget
Post Number: 568
[link removed]
86=00
96=01
Username: Jockster
thx 4 da tip
Username: Lanie
Where can I dowload bin 205?
Username: Mafri
Post Number: 8
Hello everyone, the original bin i used was from the pansatusa site, then i downloaded the other one from the al7-bar-site. it functioned for me.
Username: Rko
Whats the new code for the pansat 2007.we tried and no video or audio.Who knows the new codes.
Please comment as soon as possible.
