Pansat 2700A new bin
Username: Nunu
OK - so I loaded the new bin on my Pansat 2700A - X-87BL_070731_B75_205_api.bin and it says "Download Completed" but when my Pansat 2700A reboots, it has the 3 dashes going back and forth
The "On" indicator does not come on. Just keeps giving me the dashes incessantly.
Reloaded the original factory bin and got the "On" back. Then retried the latest bin again - same problem!
Tried the last bin X-87BL_070411_B75_203_api.bin and it did the same thing again. - - -
I had to reload the original and then the bin from Feb 2007 - X-87BL_070201_295_api.bin and it gave me the "On" again.
Anyone else having the same problem???
Please help?
Username: Richsei
Post Number: 11
yes I'm having the same thing going on..
Username: Xmongra
Post Number: 387
Install the factory bin, then install B75.
After that install 205 bin.
future-ft*info
Username: Nunu
Yup, guess I hadn't installed the boot file.
put in boot file and then new bin - looks good now!
Thanks
Username: Sat1980
Where did you get the old bin and factory bin from?
Could you please email me the files - tai86@hotmail.com
Thanks,
Username: Richsei
Post Number: 12
I would like them also.... richardat65@yahoo.com
Thanks
Username: La_bamba
where is the file of the latest BIN?
Username: Moonbeam57
where do you get the factory bin file? Please post a link to it if you can
