Hi, I have 2 2700a, superdish for 121, 110, 119 and 91. I aslo have 1 dp34 and 2 diseqc using on the 2700a. My question is very time I try to change to different sat (let say 110 to 121) will get bad channel. I think I did not do the right setting on both receivers. Can someone give me their setting if you have the same sats and hardwares? Thanks!
I'm not sure how you have your srtup configured [as you don't state].But with 121 super dish,and a dp34 with 2 recievers,and a 4th satnimiq 1/3 this is what I would do.
know you want nimiq 1/3 : on the reciever to reciever output of the dp34 ,install a short coax cable.put that into a sw21 or a 22kz switch on the off/or 13/18v side
On the 22kz port or [lnb/sat2 on the sw21] install your 91w sat coax.
Insatall the coax from your reciever to the 22kz or sw21 sw. For the bev ant setting : add sws1 switch .If you use a 22kz switch set your setting for 22kz on for bev/91w. That is for 4 sats. There are many different switches and combo's availailable but this is simple ,inexpensive and gives good fast trouble free switching and reliability.}
