They will set up the dish and any switches that you need. All you have to do is program your receiver and install the sats. This includes adjusting your settings to accomodate any type of switch they may use.
Get them to run two cables into the house if you are going to sub with dn, you can then use the fta stb and the dn one at the same time.
What type of lnb's do you have? What sats do you want? what reciver do you have? might try reading a little on these sites suggested by a senior member here: Future FTA - Blacklist's Site: [link removed] (C00LSAT and All receivers) DSS Newbies: [link removed] (Pantecs,all clones and all receivers)
File Share Site - No Registration Required: -------------------------------------------------- Good for gettting Original factory firmware: [link removed]
Best site for DISHNET info, channels, transponders and changes etc.. [link removed] [link removed] www.filez.us/km3/keys.shtml
I think i have everything figured out on the dish and pansat I just need to know how to hook up the cables from dish to both receivers I looked at a couple of sites but couldnt find any info.
ok guys i think i got everythng set up thanks to you, but my signal wont go above 30%. I know the dish is pointing right is there anything i might be over looking?
I think its the connections to the rec's because when i switched to my sub it said searching for signal so i went back to my regular connection and it worked again i cant figure out how to connect pansat and my sub rec i have tried a few things but nothing works
disconnect the AB switch for now...run cable to DN sub receiver and make sure it still works...then disconnect and run cable directly to the 2500 FTA and do a scan..if dish is aligned correctly, then FTA should get at least some "free in the clear unencrypted" channels and BOTH receivers should work...and if the sub ONLY works but NOT the FTA, then possible incorrect settings, too long cable run, or LNB's not powered correctly..and remember NOT to input cable to "antenna in" on FTA...
BTW...if the DN sub receiver doesn't come in, then U have either bad dish alignment or a tree or obstruction...or poor weather conditions..or bad cables and connections..
