Quick Ques..Possible bin issue?
Username: Mrskullz1
Brooklyn, New York
Post Number: 590
im scanning several receivers at the moment
and one of them sometimes gets the channels..but the channel name is like "Prog 112" etc...
but when i delete the channels from the sat..and rescan...it won't happen to all...then i do it again....all is good...WTF?
btw i got this is with a cw600p bin is 1.40 dated at 4-8-07
Username: Lklives
Post Number: 9966
check your cable and connections...make sure they're tight when u change receivers...and make sure ALL receivers have the same dish/antenna settings...also receivers sometimes need to be cleaned out of the memory corruption by doing a factory default and upload a factory bin before using the latest bin..
Username: Therepo
Ftaview.com
Post Number: 53
I've found that problem when scanning multiple sats on CW premium. If you auto scan (red button) each of your sats one at a time, it helps eliminate the "prog xxxx" bug.
Username: Therepo
Ftaview.com
Post Number: 54
BTW, there is 1.41 bin now.
Username: Lklives
Post Number: 9973
here ya go, if u need the 141 bin...
[link removed]
Cw600pv 1.41 06-14-2007
Premium
1. added beeping sound for signal meter in antenna setup
2. made scanning sats faster for sat 110 and 119
3. EPG timer had problems now fixed
4. fix the command with CW100R
Username: Mrskullz1
Brooklyn, New York
Post Number: 592
thanks for the heads up :-)
