Coolsat 8000hd
Username: Johnner
Miami, Florida
Post Number: 1063
All HD channels in my Coolsat 8000hd from Nimiq 82 have audio but no video except Channel 829 witch is a FTA HD preview. Please help!
Is there any key updater that tell enhansed keys?
Does antbody knows if i'm doing something wrong?
Thanks in advance!
Username: Johnner
Miami, Florida
Post Number: 1066
help!
Username: Albino_midget
Post Number: 521
[link removed]
has the enhanced keys
c/p ftabins
Enhanced Keys. 0804/0904, 0805/0905, 0806/0906.
These are additional provider IDs on Bev for certain channels. 0804/0904 is for special event sports PPV; 0805/0905 is for just three purn channels - Playbuy and two AOV channels; 0806/0906 is for the HD channels and so is important for reception of HD from Bev.
I am not sure if the enhanced keys auto roll. The keys can be entered manually by pushing Menu, then select Advance Menu with the right navigator button. Entering 1234 on the remote and the key area appears - then select NagraVision. If you have loaded the soft cam as mentioned earlier, the enhanced key slots will be in the table. Page Down on the remote brings you to page 2 with the 0805 and 0806 slots. (Some sites list as 0805 and others 0905. In the CS 8000 the keys are entered as 0805 and 0806). Look in the How To Do forum for more detail about manual key entry.
If you don't want to manually load keys, load from your PC and use the latest soft cam for the CS 8000 which will appear in the Key & Chat forum. If not all HD channels are being received, Bev could be up to their key switching routines. Make sure you find and load the very latest. Use KeyUpdate from the Key & Chat forum to find the latest keys.
Username: Johnner
Miami, Florida
Post Number: 1067
Thanks I've already download a key file containing all the keys I'll double check the keys
Username: Johnner
Miami, Florida
Post Number: 1068
OK good!
All HDs Channels working on BEV
All HDs Channels working on DISH
Thanks again!
Username: Lklives
Post Number: 9660
BS...no HD channels working on Dishnetwork!...with a CS 8000 alone..
Username: Jameslee
Post Number: 41
tvkeys is not real time a lot of the time they are way late
Username: Johnner
Miami, Florida
Post Number: 1071
James Lee
True!
LK
Sorry for the misinformation I had a wrong setting, so I was mirroring Nimiq 2.
Where can I get information about the extra equipment I would need to get them?
Can I retrofit parts from a DTV HD receiver?
Thanks again!
Username: Johnner
Miami, Florida
Post Number: 1073
Does buying an 8psk like this one, can get me DN HDs on my Coolsat 8000hd?
Do I get to keep BEV?
Why would it not do ATSC as it comes?
Is it possible that in a new BIN this would work?
I could not find much information about all this.
Please Help!
Thanks In Advance!
Username: Lklives
Post Number: 9986
heres all the coo*lsat 8000 HD info, discussions and files...
[link removed]
good luck..
Username: Therepo
Ftaview.com
Post Number: 59
CS 8000 doesn't have the physical connectability for 8psk adapter. You will just be able to view Bev.
