Help with lifetime ultra
Username: Lionking
Post Number: 33
My lifetime ultra is stuck at menu and every time i try to exit it gets stuck at the language and will not go back. I tried loading the bin again but it gives me error message
Username: Hardrockstriker
Post Number: 891
Are you loading X-85BL_070411_293T_api.bin
Username: Lionking
Post Number: 34
yes i have the 293t bin and i was successfull in loading it but agian i turn it on and i can't get past the language screen and it will not exit from there
should i scan the channels again
Post Number: 892
that's because you've lost all your config when you reloaded the bin. You will have to pick your language and do your antenna setup again.
You can't scan until you redo your config.
Username: Lionking
Post Number: 35
thanks jason i will try doing it
