Problem HH motor SG2100+ INVACOM
Username: Le74nguyen
Perris, Ca Usa
Post Number: 123
I get from ebay and install 31"dish+ SG2100+ invacom, but can not find signal. tried too many way, but nothing happen, need help. PLEASE SOME BODY CAN SHOW ME HOW TO DO IT? THANKS.
Username: Crazy_greek
Post Number: 839
linda
Try HERE......http://sadoun.net/viewtopic.php?p=22878
Perris, Ca Usa
Post Number: 125
hi.
i am trying to setup my fta. i have the sg2100 motor that has been sitting for a while, when i tighten up the bolts, and try to move the motor it stops, i lossen them up and it turns again..how can this happen, when the motor is made out of steel? im not putting preasure on the inside..i even took the cover off and it does the same thing when i tighten it...i am at my end with this mot...unless you guys have a solution..please help..
Perris, Ca Usa
Post Number: 131
anybody can help me to set up fta?? thank you!!!
Username: Satscanner
Beaversbush, Sportsmans P... Great White ...
Post Number: 1662
Without actually seeing it in operation or pysically observing it,we can't say why u have a binding problem when u tighten the bolts/nuts.
Perris, Ca Usa
Post Number: 132
ok- I fix it already- now is done- but one more problem- I don't know to set up my receiver to get Diseqc 1.2--any body help. thank you....Linda
Post Number: 1676
I don't get it.132 posts and still not up and running? Maybe u are a girl. lol
Start with the basics,then gradually upgrade.
Perris, Ca Usa
Post Number: 133
now you means- I need help to set up-- I am on a way- please help ...
I have problem about invacom- I conect 1c+ 1L calbe go to 4x4 swich-out go to invacom.. but I don't know do I do right or not? and my receiver pansat I can not swic to diseqc 1.2...any body know about install motot sg2100+ Invacom????? please show to do it...I am appreceite..thank you..
I lost four days to install but can not find any signal...It's drive me crazy....
Perris, Ca Usa
Post Number: 138
hello!! I still waiting for setup my fta-- don't means to me-thank you
Perris, Ca Usa
Post Number: 143
until now I still setup my motor sg2100- but cannot see anything yet. VSultra is cannot upgrade. Still hope waiting somebody have a lot experience onit.
Perris, Ca Usa
Post Number: 146
anybody know how to set up motor SG2100+INVACOM? please help. thanks
Perris, Ca Usa
Post Number: 147
some body help me please...thanks
Username: Pancholin
Los angeles, Ca Usa
Post Number: 74
LINDA go to find some info in this place hhp;//www.sadoun.com/satinstalation/hhmount-instalation.htm maybe help
Perris, Ca Usa
Post Number: 148
yes- I did-but still waiting for response---because ER- that's why post here and hope sombody can help.
Post Number: 1809
linda, you sure are persistant,I'll give you that.Setting up a motor isn't a easy thing if it's your first time.and I don't think anyone is gonna help,it's like teaching someone to read online.lol, I suggest you call a fta dish installer,watch him install and ask questions,while he does it. Best $50.00 you will spend,it's worth it and your tv will be up sooner.
Post Number: 1812
linda,try this:http://www.wingway.com/h2h.html
very bottom has all the links/info for you.
Username: Satscannerr
Post Number: 24
linda use the motor in you pusssyyyyyyyy and you will get the signal . but do it fast ok honey
Post Number: 875
Hey linda
A motorized Dish is not an easy system to set up,
even the pros, have trouble.
It will take time and patience.
You will need to read, test and have some one
to help you. Saying all this, here are two threads that may help you.
https://www.ecoustics.com/electronics/forum/home-video/305646.html
https://www.ecoustics.com/electronics/forum/home-video/330877.html
Make sure that you scroll down on these threads.
Username: Lklives
Post Number: 8998
give cartier a little action and he will sit on your roof and turn the dish for u all day, whenever u want to change satellites...LOL
Post Number: 1813
Hope lightning strikes him up there !
Perris, Ca Usa
Post Number: 149
SatScanner: if you don't know how to help-please shut your mouth off- or start with your new thread- don't go in here!!
I post on here because I hope somebody can show me to do it- or share with me the problem I have above-- Now what's your problem SatScanner? what's you want? you want I put in your MaMa pussssssy & dit on it? - ashole people.. get out-fuckkkkkkkk you!!!
Anyway thanks you guy- I did lost 3 week for install but can not find signal- I go to many website and read it- again & again for check what's I do worng? but I hope this week i can try it again- thanks for your response- iam very appreciate your help!!
Post Number: 1857
linda,[satscanner [bronze member] is cartier.He uses other nicks too.
Username: Cartier1
Post Number: 464
hey satscanner stop your bs ok . dont use 2 different or same names and accuse me . it;s not gonna help ok . keep playing everyone knows that.
linda he is sick satscanner he does it all the time
Post Number: 40
shut up cartier . yeah i do it so what . screww you and linda .hse is not even a girl she is shemale.
Post Number: 1862
yeah rite,cartier,you HOmMO* !
Follow the post times ,amazing how fast u change nicks,FAGG*T .
