SW44 & VS Ultra question
Username: Imnycusa
Post Number: 78
Can somebody suggest me the right VS Ultra Antenna Setup for SW44? I don't have any other switch between VS and SW44 in the configuration. Thanks.
Username: Tapeman
New York City in-HD, NY
Post Number: 1087
if you are using sw44 you just enable it
if U R not using it you say none
give me more detail on what U R trying 2 do
Username: Imnycusa
Post Number: 79
I am just adding VS Ultra to an existing setup. Presently Superdish and Dish 500 are feeding Sub DN receiver thru SW44. When I hooked up VS ultra, it kept displaying searching signal message. I could see signal strength at 100% and quality at 80%. Following is the current Antenna Setting:
119
LNB Power 18v
LNB type Universal
LNB freq 11250
22khz off
DiSEqC off
SW off
110
LNB Power 18v
LNB type Universal
LNB freq 11250
22khz off
DiSEqC off
SW off
61.5
LNB Power 18v
LNB type Universal
LNB freq 11250
22khz off
DiSEqC off
SW off
I am not sure what needs to be adjusted. Thanks for ur help.
Username: Lklives
Post Number: 9057
how about type...Dish pro or standard
SW-ON...#1-119...#2-110...#3-61.5
Username: Tapeman
Post Number: 1089
Boss you are taking away my customers again
Step-1
119
LNB Power 18v
LNB type (MATCH YOUR LNB TYPE) <<<<<
LNB freq 11250
22khz off
DiSEqC =PORT-1 <<<<<
SW =SW44 <<<<<
Do Chan Scan sat (F1)
Step-2
110
LNB Power 18v
LNB freq 11250
22khz off
DiSEqC =PORT-2 <<<<<
SW =SW44 <<<<<
Do Chan Scan Sat (F1)
Step-3
61.5
LNB Power 18v
LNB freq 11250
22khz off
DiSEqC =PORT-3 <<<<<
SW=SW44 <<<<<
If you don't know what LNB type you can try standard but it is better to match correct kind
receiver 1 and 2 turn off 0/22khz
You may have to use 0/22k on receiver 3 and 4
To allow polarity switching to all 4 receivers
Sorry I don't have manuals for this
Username: Imnycusa
Post Number: 80
Thanks guys for answering. Superdish has DPP and Dish 500 has DP LNBFs. Now since there is no option available in the menu, how do I select SW44 here? Also, even though I am not using DiSEqC switch, you have suggested to select ports 1, 2, & 3. How does that work? Are these ports corresponding to the SW44 ports in the absence of DiSEqC?
Username: Tapeman
Post Number: 1094
Is this for VS?
I think you are mixing up with VS
Username: Tapeman
Post Number: 1095
At any case
Just start setup for one receiver only
This is the only way yo'll learn by trial and error
- Select Ech-St(7) which is 119
- Select LNB type (OSD DP) for DPP
- Change SISEqC 1.0 to port-1
- Do Chan Scan Sat
- Step and repeat for Ech-St (8,10) which is 110
- Do Chan Scan Sat
If you are not happy with the setup for any reason
Reset to factory default and try again
What do U got 2 loose
Username: Imnycusa
Post Number: 81
Thanks.
