Channel 471 or 472 issues
Username: Mitulcscg
Post Number: 23
can anybody help me out , how to get channel 471 or 472,
I have all channels with latest bin file , with Blind Scan i couldnt able to get this two channels.
I want to watch CRICKET MATCH FINAL ON 28TH APRIL THAT COMES ON 471/472 CHANNEL.
I really needs it
thanks
Username: Nydas
Post Number: 2492
If you were getting the channel and just lost it, first try, switching off at the back and on after 30 seconds.
If not successful, do a specific scan for the cricket channel.
Channel Sat TP
457..... 8.1 11738 (H)
471..... 3 .. 12324 (H)
Username: Nate40
Proper antenna settings and scanning is needed on any fta receiver but the method changes a little depending on the model of receiver and lnbs you have. If you post your lnb types and antenna settings we can guide you thru the channel setup
Username: Mitulcscg
Post Number: 24
hello,
Echo 8.1 is which setellite? Can we get all English & Intenational(hindi) channels by scan this setellite??
thanks
Username: Khopdi
Post Number: 11
I am new to FTA and not an expert. But I do know that Echo 8.1 is for 110. Unless you have two dishes you can not get American and International channels.
Username: Dishvijay
on 110 there is no tp with 11738 can you post Tp#
I tried to add mannual 11.738Ghz but it ddint accept
Username: Nydas
Post Number: 2499
In the East you scan 61.5W for Internationals. In the West you scan 148W. Both these are too far from 110W and 119W - the two most popular American satellites. Therefore to get American programming and International (Hindi, Arabic etc) you have to have two dishes and a switch.
Username: Nydas
Post Number: 2500
Vijay: With my Pansat clones I can go into Menu/Installartion/edit TP and add or modify any TP number for any satellite.
Username: Dishvijay
thanks for all help
I got it
It is Tp2 on 12.239H on 110
Hope this will help for rest
Username: Mitulcscg
Post Number: 25
nalin,
i Tried so hard by TP SCAN for to get 457 &471
Channel Sat TP
but i couldnt get the quality (0 %) therefore its scans no channel, i can get level 60 but quality blank. Friend of mine used to download channellist from his laptop before , i dont know how?? and with which uploader?
whats the other alternative??
