New with pansat 2700a
Username: Angelo65
Chicago, Illinois
i just got the pansat 2700a receiver and hooked it up to my satellite dish, but I am not getting any channels. Am I doing something wrong?
do I need a program or codes or something.
Please help, I'm new at this
thanx
Username: Dude123
Post Number: 1030
ya you need to read first about the FTA and how it works and all that, its pretty straight forward. You need a bin file downloaded on to your receiver and a set of keys. With the combination of keys and bin files you get signals sent to your receiver. To get all the files and information regarding how to download and which one to download i will give u a list of sites you can visit you will need to register to read and post threir forums.
Cautin:
Downloading wrong files will damage your receiver seriously, so read before you take any actions.
I wish you good luck
Username: Dude123
Post Number: 1031
oops forgot to list the sites:
www.future-fta.info [supported by Blacklist (pansat coder)]
www.dssevolution dot com
www.dsscentral dot net
www.dssrookies dot com
www.totalfta dot com
Username: Angelo65
Chicago, Illinois
i already have the software in it
but the codes dont work
i keep getting "scrambled or bad channel"
any ideas?
Username: Wes_w
Hi Angelo,
With scrambled channels, you can turn off autoroll and manually enter the keys. It is very possable that you have older software in as well, and a new bin would work with autoroll. Unless you are positively sure it is a real pansat, make sure to use a clone safe bin. If you need any helps please feel free to stop in at FTALife website for free help, bins, and software.
Username: Satscanner
Beaversbush, Sportsmans P... Great White ...
Post Number: 1871
Lets go to fta life and spam ecoustics.
Username: Dude123
Post Number: 1035
lol
Username: Cartier1
Post Number: 467
angelo listen to the one. he gave you good advise . go read first . go t0 pansat section
you need a bl loader and the latest bin . then you need to make configuratio on your anthenna set up and you need to make sure your autoroll is on . good luck it;s for your own good to stop asking and start reading .
Post Number: 1881
cartier,you should take some of your own advise.
