Conaxsat Trio
Username: Jameslee
Post Number: 16
Conaxsat Trio
The brand new Conaxsat Trio is the triple play receiver that offers you it all. Conaxsat Trio provides all the best free to air channels with a great video tuner to give you a great picture. Conaxsat Trio is a personal video recorder by USB 2.0 port. This allows you to tape and recode all the best shows using the Conaxsat Trio. Conaxsat Trio has 2 usb ports which allows you to use one for a hard drive and one for a usb memory card for software bin file updates. Conaxsat Trio provides all the best features like fast scan power scan blind scan closed caption support parental lock digital audio smart card reader and Conaxsat Trio even supports divX. You can play DivX movies on the Conaxsat Trio. Plays movie and music files like MP3 MPEG DAT DIVX3-5. This is a great fta free to air receiver.
http://www.conaxsatfta.com/Conaxsat-Trio-CNXTRIO.html
Conaxsat Trio
Conaxsat Trio Free To Air Satellite TV Receiver
Conaxsat Trio
Conaxsat Trio CNXTRIO Digital Free To Air TV Receiver!
For all you help support software guides and much much more go to
FTA Forum Index
THE BEST CONAXSAT RECEIVER ON THE MARKET!
Conaxsat Trio On Screen Channel Guide
Conaxsat Trio Channel Search Page Free To Air Satellite
Conaxsat Trio Plays DIVX Movies!!
Conaxsat Trio Picture And Current Channel Guide & Next!
Conaxsat Trio Features:
- Personal Video Recorder (PVR) Ready via USB 2.0
- Reserve Recording in EPG Mode
- Recorded file play on PC
- Upgrade Software & Update Channel Database through USB 2.0 Port
and RS232
- Two USB 2.0 Host for USB Storage Devices (e.g. External HDD, USB Memory, etc)
- MP3/JPEG File Store and Play via USB 2.0
- Vacuum Fluorescent Display (VFD) Type of Front Panel Display
- MPEG-II Digital & Fully DVB Compliant.
- C/KU band control for each antenna
- LNB Tone Switch 22KHz mode on/off'- Multi-LNB controlled by DiSEqC 1.0, 1.2 and USALS'- Total 5,000 Channels Programmable
- Blind Scan
- Closed Caption Support
- Parental Lock
- PAL/NTSC automatic conversion
- Picture In Graphic (PIG)'- Teletext and subtitle directly from the On-screen Display (OSD)
- Electronic Program Guide (EPG) for On Screen Channel Information
- Zoom Function by 2x.....4x
- Game function with Stereo Sound
- Dolby Digital Bitstream Out through S/PDIF
- CVBS Video & Audio Output via RCA
- Component Y/Pb/Pr Output via RCA
- S-Video Output
- Universal Remote Control
- Multi-language supported for Menu and OSD
- Built-in Smart Card Reader
THIS FREE TO AIR CONAXSAT RECEIVER HAS 2 USB PORTS FOR MORE USE!
Conaxsat Trio DivX Player
- Dual Core System (STB:180 MIPS, 32MB RAM, 4MB ROM and DivX Video Player: ARM9 266MHz, 32MB RAM )
- Movie/MP3 Jukebox/Photo Album play while PVR in Function
- DivX Video Player supports both FAT32 and NTFS HDD Formats
- DivX Video Player supports HD Component( 480p, 720p, 1080i) to enhance Maximum Picture Quality
- Play universal movie file formats (e.g. MPG, MPEG, DAT, VOB, AVI: XviD, DivX3.x/4.x/5.x)*
- Play universal music file formats (e.g. MP3, WMA, AC3, Ogg Vorbis)
*XviD: Not compatible with Qpel and GMC encoding methods
Conaxsat Trio Games Movies Juke Box Album
Conaxsat Trio Specifications:
Conditional Access Interface
- SMART CARD 1 Slot: ISO 7816, GSM11.11 and EMV (payment systems) compatibility
Conaxsat Trio Tuner & Channel
- Type 1 ? F Type, IEC169-24, Female
- Frequency Range 950MHz to 2150MHz
- RF Impedance 75 Ohm unbanlanced
- Signal Level -90 to -20 dBm
- LNB Power 13.5/18.5Vdc +/- 5%, 0.5Amax, Overload Protected
- 22KHz Tone Frequency : 22KHz +/- 2KHz, 0.6Vpp +/- 0.2V
- DiSEqC Control Version1.0, 1.2, Tone burst A/B
- Demodulation QPSK
- Input Symbol Rate 2~45 Ms/s, SCPC/MCPC
- FEC Decoder Convolution Code Rate 1/2, 2/3, 3/4, 5/6 and 7/8
With Constraint Length K = 7
Conaxsat Trio System & Memory
- Main Processor 32-bit ARM946 RISC Processor
- Flash Memory 4 Mbytes
- System Memory 32 Mbytes
- Channel Capacity Digital Channel: 5,000
- Front VFD Display (3 Icon, 5 digit Alphanumeric)
Conaxsat Trio MPEG Transport Stream & A/V Decoding
- Transport Stream MPEG-2 ISO/IEC 13818 Transport Stream Specification
- Profile Level MPEG-2 http://www.conaxsatfta.com/Conaxsat-Trio-CNXTRIO.html
Username: Jameslee
Post Number: 17
The most advanced and powerful free to air receiver on the market. conaxsat trio has 2 USB ports while sonicview 4000 cool sat 7000pvr and viewsat ultra all have one. Use the conaxsat trio as a PVR personal video recorder.
