How do I install new keys for Pansat 3500SD?
Username: Khopdi
I recently bought Pansat 3500 SD box and I am very new to this hobby. For Dish, keys were changed yesterday and I don't know how to install the new ones I have using the remote control. Please help. TIA.
Username: Hardrockstriker
Post Number: 754
In your menu system:
Parental Control -> Second Pin
then put it "0000" for the code
Once you're in you'll have to select Nagra2
or put on the latest bin which has a working autoroll
Username: Keanos
Post Number: 49
Username: Keanos
Post Number: 50
How do I install new keys for buzz
Username: Thunder_lightning
Post Number: 224
Pansats: C/P FROM MC
1. Hit the Menu button.
2. Then scroll down to Parental Code, and hit "OK".
3. Then go to Second Pin and enter all zeros. (0000)
4. Now scroll down to Nagravision 2 and hit "OK"
5. On Provider ID, select the Provider you need, Dish Net, or Bev.
6. Move down to Key Number. Depending on what key you need to enter, you will change the key number by using the left or right arrows only. Key 86 is the same as Key Number 00, and Key 96 is the same as Key Number 01.
7. At the bottom of the page it will tell you which buttons to use to get the
appropriate letters for your keys.
8. Once you have changed the necessary keys, hit the "OK" button and make sure that the "OK Store" words blink at the bottom right corner.
9. Exit all the way out of your Menu, and change channel.
10. Watch TV.
Post Number: 225
John this 4 your Buzz
Buzz: C/P FROM MC
1. Hit the "Menu" button.
2. Then scroll down to "Entertainment" and hit the "OK" button.
3. Then scroll down and highlight "Sokoban" then press 7890.
4. You should then see "Code" appear and be flashing. Highlight it and Press "OK."
5. Then scroll down to Nagravision .
6. Move to Dish and make sure it is 0101 for dish and for BEV 0901.
7. Enter the first half of Key 86 (Key 00) in line 10.
8. Then enter the second half of Key 86 (Key 01) in line 11.
9. Then Enter the first half of Key 96 (Key 01) in line 20.
10. Then Enter the second half of Key 96 (Key 01) in line 21.
11. Then Exit out.
12. Change channel and watch TV
Username: Gkp511
Hi
My 2700a accepted the keys and started working but it jumps keys after sometime.
Any suggestion
Post Number: 756
Get the latest bin. It will have a properly-working autoroll.
