Converting Fortec Star Lifetime Ultra to Pansat 2500 clone
Username: Missdju
Tried downloading bin 292t but now the screen freezes and the receiver doesn't seem to be capting any satellites. I'd never done this before I am positive I downloaded the bin file properly. From what I've read on various websites, it seems I should maybe convert me Fortec and turn it into a Pansat 2500a clone. Would that help? Or should I try downloading an older bin file? I've also read about using the factory reset to fix some bugs...should I try that? Any help would be greatly appreciated.
Thanks!
Username: Nydas
Post Number: 2291
All BINs that work on Pansat 2500 clones work on Fortec Ultra.
Try loading the factory BIN or 280T or 281T. Also do factory reset. Then load 289T or 292T. You will have to rescan.
289T requires manual key entry but is otherwise reasonably stable. If it works then blame the 292T for your problems.
Username: Missdju
I just wanted to thank you for helping me. I did exactly what you suggested and it fixed my problem. Thanks so much for taking the time to help me out!!!! :-)
