FREE Anti virus and Anti spyware programs here
Username: Lklives
Post Number: 8600
Ad-Aware..considered the one of the best anti spyware, better than the Norton and Macfee paid programs..and updates daily...
http://www.download.com/Ad-Aware-SE-Personal-Edition/3000-8022_4-10045910.html?p art=dl-ad-aware&subj=dl&tag=top5
spybot..another anti spyware
http://www.safer-networking.org/en/download/index.html
Spywareblaster 3.51 ..another great anti spyware
http://www.javacoolsoftware.com/
AVG 7.5 Anti Virus ...FREE and considered the BEST of all anti VIRUS programs
http://www.grisoft.com/doc/31/us/crp/0?prd=isw
I use all of the above..1 anti spyware program will not catch it all, so its suggested to use a few...the AVG 7.5 anti virus cannot be used with another antivirus program, but this is the best and free...U can Only use 1 anti virus program on your computer but can install and use all 3 anti Spywares and the 1 anti virus....
Username: Ken_1
hi1 plz help
i have a laptop and i just bought the usb to com converter, but on the uploader program i see only 4 com settings, how do i select or find the uploader that has more com settings
Username: Lklives
Post Number: 8602
Go post in a more appropriate thread...don't try and hijack this thread on YOUR first post here...learn how to use forums!
BTW...many USB adapters don't work with FTA receivers..and U will need the driver for it too..and another updater doesn't have more comport settings!...U need to go read!
Username: Rcfiddlerman
Post Number: 30
thanks for the info, oh and there is also trend micro they have a housecall scan that works pretty good too http://housecall65.trendmicro.com/
Username: Hockeys_back
Post Number: 51
Hey LK,
Thanks for the sites, my norton just expired, and was looking for a new anti virus, guess i'l use this one.
Thanks
Post Number: 52
it ask's for a license/sales number
Username: Lklives
Post Number: 8613
None of these ask or need a livense #...
Username: Lklives
Post Number: 8614
BTW...reuse your Norton if U want, through control panel uninstall it and then reinstall it..
Username: Doreenakadj
Post Number: 337
what Norton are you /were useing hockeys? if it requires a new key i can get that for you or at least try... BTW you can't just uninstall and reinstall anything without getting ride of the registration keys first ,, windows keeps a log of all activity and knows if it expires or not.
Username: Satscanner
Beaversbush, Sportsmans P... Great White ...
Post Number: 1688
Yes! Dorreen ,people here know you are are a pc wiz.
Warning! Doreen is a hacker and a pc wiz!
Username: Thunder_lightning
Post Number: 193
Norton AntiVirus 2007 XP & Vista + Keygen...
http://www.mininova.org/tor/633092..
after you downloading this you need to burn it into the CD...disconnect your internet b4 you install this software or it will not work...and try to read the 23 comments in that links there are insruction from some poster...
it will update for you for 3650 days....i install it a few days now and it working great...
Post Number: 194
the Damn link is not working...need another link...
Post Number: 195
this is the link..http://www.mininova.org/search/?search=norton%20antivirus%202007
this is the one it work..
Norton AntiVirus 2007 XP & Vista + Keygen - [www slotorrent net].....101.96MB
Post Number: 53
LK......the program AVG 7.5 Anti Virus does ask for a key.....it ask's for my name, organization, and key number
Username: Lklives
Post Number: 8633
Hockey...here...use this link..all U had to do was look there!
http://www.download.com/AVG-Anti-Virus-Free-Edition/3000-2239_4-10645435.html
Username: Sccrskills
Post Number: 42
hey guys i use the at+t yahoo online protection do u think i should switch and use avg or norton and if so which one of the two would be better cuz i hear bit deffender is one of the best right now. thanks
Username: Angie_wedgewood
Post Number: 46
THUNDER, when I try and download that program off mininova it keeps trying to download it with my Ares program, but it won't work. Any idea why this is happening and how I can just get it to download normally? Thanks!
Username: Lklives
Post Number: 8699
Post Number: 199
Angie use BitComet0.86 to downnload..that what i used..
http://www.download.com/BitComet/3000-2196-10296306.html?part=dl-BitComet&subj=u o&tag=button
Post Number: 47
Awesome thanks for the help:-)
