Pansat 2700 echo 8
Username: Chrisduclo
Post Number: 19
i seem to be having trouble switching channels from echo7 to echo8 but not from echo8 to echo7. a power off/on is needed to get reception which resets my epg... any sujestions for this problem?
Post Number: 22
bump
Username: Lklives
Post Number: 8661
U should replace the switch..and if using a pansat 2500, try an older bin such as 288 and manually enter the keys..
Username: Nikk
Post Number: 1625
I agree with LK...replace the switch first....then try the second suggestion
