Did any1 hav trouble with wrestlmania 23?
Username: Djxotic
i found the confirmation chanel then went to designated chanels but no go. will it be the same for boxing ppv?
Username: Hawaiian_time
Kanaka freak...
Post Number: 975
455 on Echo 7 was fine.
Kanaka freak...
Post Number: 976
Maybe you need to rescan channels.
Username: Djxotic
rescan on dn also?
Kanaka freak...
Post Number: 977
The only trouble I had with Wrestlemania is that Trump didn't get his head shaved. (like that would ever happen) But at least he got stunned by Stone Cold.
Kanaka freak...
Post Number: 978
I rescanned a couple a weeks back when I lost 455. I just rescanned all of the Sats because it's easy with my VS.
Kanaka freak...
Post Number: 979
If you decide to do that, make sure you set the factory default/settings first. By the way, which satellites are you using?
Username: Djxotic
d/net. i get everything else except 455 & 472
