Picture not sharp
Username: 4play
Post Number: 24
Has anyone had the problem or still having the problem with the picture not being sharp or real clear. I have a pansat 2500 and i'm using dish 500 with dish pro twin lnb. Both level and quality are over 90%. Any ideas? Thanks
Username: Cartier1
Post Number: 33
yeah .mike if u wanna have the picture sharp with pansat 2500 . use windex or there is a polish liquid that you can buy and drop it inside the box while it's on and the picture will be just cristal clear .
Username: Leew
XXXX!!WWWW, Yokosuka, ... Holla Back Y...
Post Number: 1399
Username: Nikk
Post Number: 1359
mike...
Check or replace the cable that goes from your receiver to your TV, it is nothign related to you bos, it is something between your receiver and the TV
Username: 4play
Post Number: 25
CARTIER: Ha Ha you're a funny guy. Nikk thanks for the advice. there's nothing in the line. i'll try to change the cable. I don't think its bad but i'll see if that makes a difference.......
Username: Cartier1
Post Number: 44
MIKE WHAT TV YOU HAVE? AND WHAT CONNECTION ARE YOU USING ? WHAT DO U MEAN BY REAL CLEAR?
Username: Crazy_greek
Post Number: 687
Hey waters
First unplug your receiver, wait then
plug it back in.
Here are a few of Possible Causes.
1) Loose Connections.
2) Moisture, outside connections.
3) Short in wiring.
4) Appliance on the same circuit as TV.
5) Ajust the setting on TV.
6) TV.
Username: Lroy
Post Number: 192
Mike I don't know how you have your box connected to your TV, but this is my suggestion, use one of the following connections if you have not done it yet.
1. Use S-Video cable
2. Component cable
3. RCA audio video cables
Username: 4play
Post Number: 26
I have a panasonic 32" tv. I'm using rca cables going from the receiver to the tv. The picture looks real grainy. I tried a new set of rca cables and my regular cable is giving me a better picture then the pansat. It's looks like if you look real close it looks like real tiny squares in the picture.
Username: Jay_grayson
Chicago, Illinois U.S.
Post Number: 15
Mike, are all the channels bad? Some channels are a very low bitrate they try to squeeze as many channels as they can on one transponder....I have the same problem. Try different channels typically the foreign and local channels are crappy.
Username: 4play
Post Number: 27
i get the same picture on all the channels.
