Captiveworks 600S Premium VS Viewsat Extreme?
Username: Boki
Post Number: 8
i have a VS Extreme and am thinking about buying a Captiveworks 600S Premium. Which one has better and faster EPG and channel changing? Are they almost the same?
Username: Lklives
Post Number: 7907
If U are happy with your Extreme, buy another one...why have 2 different receivers, if U are satisfied with present one..
Username: Boki
Post Number: 9
Can anyone help me with my VS Extreme when i change channels sometimes on every other channel it says "Searching for Sattelite" or if my AutoRoll is ON it says "AutoRoll Processing". in order for me to get the picture i have to turn off my STB with a remote and turn it back on. What could be the problem?
Username: Boki
Post Number: 10
it usually happend when i switch between the sattelites. I only run 119 and 110
Username: Brucester
Post Number: 311
i got cw600p epg works good get 3 day for bev and 7 for dish channel change is slower it is 1 or 2 sec after you change it no big deal and it got pip and the last couple of times cw come out with the fix faster then viewsat and cw got this thing called card sharing so if the fta goes down you can card share via internet and lots more neat things this box rocks for 105 with the new cw-100r pvr add on for 139 cant go wrong and is getting good reviews.hope this helps you have a nice day
