Scanned all but not getting all channels
Username: Reach_honey
Post Number: 34
I have just loaded 289t bin .
I have scanned 119,110,61.5 and 148
But still not getting all international channels.
Does this require specific SKEW number,.
Can any one post SKEW number here for all above angels/directions.
Thanks in advance.
Username: Crazy_greek
Post Number: 703
Hey reach
Are you on a Motorized Dish, or three (3)
separate.If is not a Motorized Dish, I
will need your Zip Code in order to
answer your question.
Username: Lklives
Post Number: 8006
Satellite Finders (Look Angle Calculators)
[link removed]
http://www.hollsco.com/Products/SatCalc/
http://www3.telus.net/rampage/skew.htm (Dish 500 support)
http://www.remotesat.com/lookangle.htm
Username: Jay4u
Post Number: 17
hey guys i have a problem with some of my channels(indian Channels) i only get 4 channels out of 14 .......... any sugestion
Username: Nydas
Post Number: 2043
In most cases like this, it is the fault of the BIN. BIN 289T is OK and will give 100% of Indian channels , but you are stuck with manual entry of keys. With the 290T BIN you will miss some of the Indian channels, but you will have the autoroll. Click on URL below for fuller details about this.
https://www.ecoustics.com/electronics/forum/home-video/326678.html
With 289T and with 290T, you also occasionally need to do a TP scan of some of the Indian Cahnnels, notably ZEETV. This happens even after a Blind scan and even after starting afresh with factory reset, so don't bother with factory reset - you will only waste time.
I get the odd freeze or reset with 289T, and, of course, I have to manually enter the keys, but it is worth it, because I have all the Indo-Pakistani channels on a Pansat 2500 clone.
Username: Lklives
Post Number: 8024
Sometimes receivers get corrupted and a Factory Reset or uploading a Factory bin is required to clean it up..contrary to a non testers opinion above...
Username: Nydas
Post Number: 2046
LK: Did you even bother to read the testing I did specifically for the 290T BIN? You are the non-tester, not me.
All along you have ignored the fact that EVERYBODY who is using the 290T BIN is having problems with the International channels. So why do you keep on sending them on a wild goose chase of satellite angles and corrupt receivers?
You do not watch the Indian channels under scutiny here, so butt out of here.
Username: Mkvl1490
Post Number: 98
man dis box is gettin on my nerves, i tried everything. put tha keys in, turn tha box off, turned off autoroll. it keep sayin waiting for pic. i got tha 290 bin and it still not comin in
Username: Lklives
Post Number: 8027
U have stated yourself publicly here on a few ocassions, that U DO NOT TEST!...that U do NOT need to test because U read things instead, and therefore TESTING is NOT required!!
I am ONLY correcting another BOGUS statement that U have made, stating that there is never a need to do "factory reset", because U have loaded 100 bins in your crappy pantec and have never done one..
Username: Nydas
Post Number: 2049
LK: You are the one resting on some ancient experience and posts of people at your site, not me.
STOP CHASING ME. You are not ging to get any sexxual satisfaction here.
Username: Nydas
Post Number: 2050
Makaveli : You said you have 290T BIN loaded.
1. check your clock and date and time zone.
2. do autotroll off.
3. do set default keys.
4. Keep autoroll off and enter Key 00 and Key 01 of your provider manually. Provider ID is 0101 for DN and 0901 for BEV.
5. SAVE.
6. Swithc off at back. Wait a full 40 seconds and turn it on.
Username: Lklives
Post Number: 8029
Nalin...so a blow job is out of the question?...LMAO
Username: Nydas
Post Number: 2052
You depraved person. Get back to Afghanistan.
Username: Lklives
Post Number: 8035
why don't U go back to India?
Username: Nydas
Post Number: 2055
Why don't you go back to Ireland?
