FORTEC STAR LIFETIME ULTRA HELP!!
Username: Shacck
Post Number: 20
Hello to all!! I am having lots of problems downloading the new bin for this stb.I am using the same cable i use for my pansat 2500 but its not allowing any downloads. I am also using black list 1.4.0 loader but the writing part is failing. This what i've tried:
tried everything to load file to box.
with null and stright cable but no luck.
tried all Blist loaders,fortec loaders,the one that ask the model and the one that donot ask the model number but nothing.
turn it on from back hit downlade but reciver power on with "on"on display.
tryied power on,power off then on ,with 1st dot on display etc .
is my serial port dead?
Can anyone help me????????
Username: Prfrmnj
Post Number: 2009
Your computer is not communicating with the box. This is a com port problem. You need to make sure that there isn't anything else using that com port.
