F.L.U. Help
Username: Jaa
when i try to download 288t file it says model name does not correct. i haven't used my ftu since march of 06 do to house fire.any responce appreciated
Username: Nikk
Post Number: 1134
which loader are you trying to use???
Better to get BL loader 1.4, you don't have to type any model number there....
You can also try put 2500A and see what happens..
Username: Jaa
In the STB Model i put fortec lifetime ultra and a sign pops up and says model name does not correct. i use the 3.1 updater. i don't have original updater it was on disk when i bought fortec and lost in house fire
Username: Ars88
P.I.M.P , Pakistani/In... United States
Post Number: 487
use bl loader 1.4 for those files....bl loader always works for me
i did have issues with te stb loader as well so jus stick with bl loader and all should be good
Username: Jaa
Post Number: 7
i had to buy a new cord for my fortec to go to the computer and it has NM (Null Modem) on it could that be why when i download file it says model name does not correct or failed. I used Bl 1.4 updater and couple other ones never had problem before could it be the new cord? any help appreciated
Username: Crazy_greek
Post Number: 573
Hey JAA
Go here, I think this thread will help you.
https://www.ecoustics.com/electronics/forum/home-video/274416.html
