Echostar 8.6 help
Username: Asifali418
Lodi, Ca Usa
Post Number: 21
hi i need help i use view sat2000.before its work good but now its not work on echo 8.6 i use 3 satelite i use dish 500 with 2 lnb for echo star 7 and 8.6 beforei put echo starin port 1 and echo star 8.6 in port2 .but now its not work i got the signal but whin i press F1 key for scan no channle and the signle is gone .and echo 7 work good.and also 1.2 work good too .can u tell me who i found nimaq 2 82 w thnkas
Username: Bones714
Somewhere fi...
Post Number: 245
check all your connections, diseqc
Username: Ravensunstar
Carleton place, Ontario Canada
wow where is dssevolutions I so love that site darn???????????LOOKIN for key codes also for BEV any one can help pls}
Lodi, Ca Usa
Post Number: 22
i checked diseqc. i put it on 1 and 148 i put it on 3 before i got the signal same i put on 1 and in the reciveer port 1 for 7 and port 2 for 8.6 and port 3 for 148 w imean 1.2 but now some problem.
Username: Crazy_greek
Post Number: 553
http://www.dssevolution.com
