Cant get into setup wizard [8300HDv2.2]
Username: Neirin
Good Evening,
On monday my regular box died so I brought it in and since I have a hdtv I decided to trade up for a DVR box.
I have the SA 8300HD v2.2 and I try following what the manual says, leave TV on, keep box powered off but plugged into working socket. I do the guide + info and all I get is a message that says Press "cbl" to turn on your cable box.
So then I went on to SAs site and found their .pdf manual and it says press cbl on the remote to put the remote into cbl mode and I figured that would help, but no go.
For reference I live in orange county new york and Time Warner Cable is my provider.
Thanks in advance...
Username: Tapeman
Post Number: 557
No
Cable box must be off during this setup. TV on
You must press (Guide and info) at same time from the box not the remote control
Need to Register?
Forgot Password?
Enable HTML code in message
