Up to Date Channel List
Username: Book77
Post Number: 24
Where can i find an " UP TO DATE" channel list for Charlie 110 and 119.
I did a a new scan I have so many repeats now.
Any info would be helpful
Username: Prfrmnj
Post Number: 1610
Jim - Go to Dss testers. Download the latest list by "El Vaquero".
http://forums.dsstester .com/vbb/forumdisplay.php?f=85
Cut and past onto browser and remove space between dsstester and the .com
Username: Buffalo
MontrealCanada
how i can use the 110 119 from a dish 500 lnb with built in switch i cannot scan both dishes
i have fortrec
Username: Xtrawest
Post Number: 54
http://ekb.dbstalk.com/dishlist.htm
Username: Prfrmnj
Post Number: 1769
Perfect Scan with Dish500 and DishPro (Twin or Quad) LNB
-First you will need to reset factory defaults
-Then go into your Antenna Setup and configure
NOTE: If you are using Fortec or Pansat you will need to unselect the bird you are not scanning. To do this, use the arrows on your remote to deselect the sat.
- You will then set your LNB type to Standard and select the port on the DISEcQ where for this sat (119 = 1 & 110 = 2).
NOTE: If you are scanning 119 then 110 should be unselected and in the DISEcQ option it should read NONE.
- Now commence your blind scan.
NOTE: At the end of this process do the same for next sat repeating the steps above. Once you have completed all scans you will need to go back and reconfigure your antennas as follows:
For Fortecs and Pansats:
LNB TYPE = DishPro
DISEcQ -- 119 = 1 and 110 = 2.
The remaining options will stay the same. Keep in mind that depending on your location you may or may not have any signal on the first TP that appears in your settings for 119. Do not alarm yourself with this.
For Viewsat Owners the steps are pretty similar, but all you do is turn the LNB Power Off in the Antenna Setup.
Once completed you will need to reconfigure as follows:
LNB TYPE = OSC-DP
Enjoy!!!!
Username: Book77
Post Number: 35
Any good steps for Captive Works 600S
Thanks Jim
Username: Prfrmnj
Post Number: 1773
Jim - You could try the above, but I don't test with Captive Works so I really wouldn't know if it would apply.
Username: Brucester
Post Number: 199
jim budy you have to go to one of the sites me and others give to you you will find the info under capative works 600s not 600p there are no files on this site glad to see you got your box working
Username: Brucester
Post Number: 200
jim not sure if this is what you want but you have to go pic one from the site this is an example of one i found dish_channellist_ForKround got it from dssrookie* com chang the star to a dot have fun
