Viewsat ultra help needed
Username: Steph_raven
Les Cedres, Quebec Canada
Post Number: 27
from one problem to the next!!!
i just brought home a viewsat ultra. downloaded the loader 2 and chaninfo-may-01-06.cha, SatInfo_ May-01-06.sat, 01-10-2007_opkey.hex, and PFTAUSW-070125U.PGM(which is the most recent)
i can't get the blxxdy thing to work.
i think i did everything i was suppose to. there's no where in the menu to choose code, to enter keys? no autoroll option....anybody got a sludge hammer??? lol
a quote from the wise "you carry the faith of us all little one" lol
Username: Chessy
Post Number: 30
you need to load bin 117 first it is a factory bin then load 119 and then the last new bin... once you put in the factory bin your code will apper you will not have to enter keys as it auto rolls quick
Post Number: 28
i will try...i'll be back...thanks Chessy!!
Post Number: 29
k..the bin 117 is identified by PFTAUSW-070117U.PGM the 117 at the end??
Username: Mc_sunny
Post Number: 1032
step by step using only serial null modem no usb needed!
1 Load VSULTRA_v117_factory_bin.pgm
2 Load DBPSW-061127U_A.PGM
3 Load the latest xxxxxx-xxxxxxU pgm file in the ultra section + your sat and channel files
4 Optional load your openkey file or wait for your autoroll
Username: Ke5aqn
Shawnee, OK USA
Post Number: 615
Their were new bin's released in the past few day's. PFTAUSW-070125U.PGM is the newest bin for that receiver. You can get it from here.
Then you can follow the instructions here by Mc Sunny .
To my shadow,
I feel I answered in the best way possible for this moment. I feel it unnecessary to explain in great detail a bin that is not for his receiver, how to load a file with a serial port and cord, or how to unzip a file. Thanks
Post Number: 30
b 4 i start installing please tell me if these are ok
VS2000-v0501-ALPU-20051108factory
DBPSW-061127U_B
PFTAUSW-070117U.PGM
it's what i could find on dsstester
thanks!!
Username: Ke5aqn
Shawnee, OK USA
Post Number: 616
Stephane please see my post above. You have everything correct except their is a newer bin for you to use..
here is some release notes on it
Release VS XTREME ULTRA Note
PFTAUSW-070125U
* Versions
- Release Date : 2007.01.25
- Main software : PFTAUSW-070125U
- Boot Ver : 0.0B
* Change
(Main software upgrade)
PFTAUSW-070124U
* Versions
- Release Date : 2007.01.24
- Main software : PFTAUSW-070124U
- Boot Ver : 0.0B
* Change
- Local Channel - Some missing channel added & Puerto Rico added
- Display Information of the Song in Live Radio Channel (Changed)
PFTAUSW-070117U
* Versions
- Release Date : 2007.01.17
- Main software : PFTAUSW-070117U
- Boot Ver : 0.0B
* Change
- Channel Block - You can not see like adult channels when you set maturity rate.
- Wider Plate of Channel name display in Channel Guide
PFTAUSW-070104U
* Versions
- Release Date : 2007.01.04
- Main software : PFTAUSW-070104U
- Boot Ver : 0.0B
* Change
PFTAUSW-070103U
* Versions
- Release Date : 2007.01.03
- Main software : PFTAUSW-070103U
- Boot Ver : 0.0B
* Change
- Sleep Timer
- Display Violence/Nu%dity/Language in R,NC-17,UR
- Timer Event
- Add Favorite List in Live
- Channel Search with Channel Name in Theme
- Channel Search in Live
- Closed Caption On/Off in Live
PFTAUSW-061220U
* Versions
- Release Date : 2006.12.20
- Main software : PFTAUSW-061220U
- Boot Ver : 0.0B
* Change
- GC Supported
PFTAUSW-061218U
* Versions
- Release Date : 2006.12.18
- Main software : PFTAUSW-061218U
- Boot Ver : 0.0B
* Change
- Local Ch Select
- Bell-Vu CH Mapping Menu
- All Ch Delete in Ch Edit
- Previouse Ch (List/Direct)
PFTAUSW-061213U
* Versions
- Release Date : 2006.12.13
- Main software : PFTAUSW-061213U
- Boot Ver : 0.0B
* Change
PFTAUSW-061129U
* Versions
- Release Date : 2006.11.29
- Main software : PFTAUSW-061129U
- Boot Ver : 0.0B
* Change
- It support VSTV
PFTAUSW-061127U
* Versions
- Release Date : 2006.11.27
- Main software : PFTAUSW-061127U
- Boot Ver : 0.0B
* Change
PFTAUSW-061124U
* Versions
- Release Date : 2006.11.24
- Main software : PFTAUSW-061124U
- Boot Ver : 0.0B
* Change
PFTAUSW-061121U
* Versions
- Release Date : 2006.11.21
- Main software : PFTAUSW-061121U
- Boot Ver : 0.0B
* Change
PFTAUSW-061030U
* Versions
- Release Date : 2006.10.30
- Main software : PFTAUSW-061030U
- Boot Ver : 0.09
* Change
PFTAUSW-061024A
* Versions
- Release Date : 2006.10.24
- Main software : PFTAUSW-061024A
- Boot Ver : 0.08
* Change
- Set to Set Upgrade problem.
- Audio noise problem.
- USB Function Added. (*.HEX)
- Read KEY_DATA problem.
- Changed ALPU Check routine (5 MIN -> 10 SEC)
- Boot version check.
(Boot software upgrade)
- Handshaking problem.
Post Number: 31
thanks and sorry Jay but i was typing while you
posted...
Username: Ke5aqn
Shawnee, OK USA
Post Number: 617
Its cool happens all the time matter of fact several times this week!
Post Number: 32
i'm doing blind scan...i have code option...so i'm on my way to free tv....i hope...lol
thanks guys....i'll be back!!!
Username: Ke5aqn
Shawnee, OK USA
Post Number: 618
You will be fine and enjoying free tv soon I have 625 channels here with DN and BEV good luck!
Post Number: 33
ahhhhh with amazement and total satisfaction!!
THANK YOU PEOPLE!!! who wants a kiss...lol just joking!!! i'm a very satisfied heterosexual. i'm just easlily please!!! plus you guys live way too far!!! now that i got that going, i have to get dn!!!
i really thought i was going to lose it!!!
this ultra is not as easy as the pansat...i hope to enjoy it more. thanks again guys!!!
Username: Ke5aqn
Shawnee, OK USA
Post Number: 619
No prob Stephane and yes you should have DN goog movie channels on it......
Post Number: 36
i came home 2-nite and my ultra was down. the message on screen was about autoroll processing?
i turned it off for 1/2h and still the same thing...isn't it suppose to autoroll? i entered keys manually et voila...tv was working again...i have the latest bin in there..any ideas??
Username: Mc_sunny
Post Number: 1054
check if ur AUTOROLL IS ON, if it is off turn it ON then
Username: Prfrmnj
Post Number: 1744
Stephane - Tune to channel 105 and then let it roll. Then chance to channel 300.
Username: Prfrmnj
Post Number: 1745
Oops type. tune 105 and then 300. That should solve...
Post Number: 37
is this like an unwritten rule? ch105 then ch300?
Username: Prfrmnj
Post Number: 1746
Not really. It's just what I do when that happens. Did it work?
Post Number: 39
i actually updated the keys manually...but i will surely try next time. I was told to shut the switch off for about 20mins and i would b good....hummm ill try the 105/300 next time. i didn't see any new threads about vs or new bins so i new it was the keys. thanks!!
Username: Prfrmnj
Post Number: 1749
I have that problem every now and then. Some channels don't roll as fast as others. I always find that 105 rolls rather quickly and then I just tune to 300 to double check. But there is really nothing set in stone. Some people use different channels. The point of this drill is to find a channel with good signal and allow the keys to roll...
Post Number: 40
Mc Sunny, my autoroll was on, i did try it off and then back on. thanks...like i said, i entered the keys manually. It's all about testing......i do have my bev package but ppv's r nice when they r FREE!!! LOL
Username: Prfrmnj
Post Number: 1751
Stephane - Mc Sunny is one of the more knowledgeable people here. I just try to add options, but he's normally on the money!
Post Number: 41
Prfrmnj, why is my signal at 100% with bev 2700 rec'r andonly about 72% with VS? the quality is about 80 to 100% i sometimes see 67% but mainly all above 80%
Username: Prfrmnj
Post Number: 1756
Can't answer that without your entire system setup. It could be a lot of things.
Post Number: 43
what do you need to know? it was the same with pansat 2700 clone. the signal was never 100% but was higher the vs
Username: Prfrmnj
Post Number: 1760
Stephane - I'm not sure I understand. I do not test on bev because of my location. Can't help you with that... Hopefully someone here can asnwer. I do know that different receivers give you different readings. For example, in Puerto Rico when I use a 6 foot dish I get 115 signal with the DN 311, but yet my VS only reads about 90. I would assume it's not different with you.
Post Number: 45
k thanks!!
