Intermittent Signal Loss on 61.5 (Pansat 3500)
Username: Tamizhan
I am seeing intermittent signal loss on 61.5 while the 110 and 119 signals are perfectly fine. The signal quality shoots up to 90+ and then lowers to 0 within seconds. I started seeing this issue for the past couple of days. Can someone please explain why and suggest how to rectify it ? I am using the latest bin for Pansat. I also checked the antennas and they have a clear view.
Username: Ke5aqn
Shawnee, OK USA
Post Number: 666
Have you checked your disteq switch ? I had that once and that was the trouble.....
Username: Satscanner
Beaversbush, Sportsmans P... Great White ...
Post Number: 916
Jay,what happened to your shadow?
Username: Tamizhan
thanks Jay. its fixed now.
