Where is 289T .......???
Username: Biverland
Post Number: 77
Where is 289T safe for Fortec Ultra & Clones ??Upload
Username: Brucester
Post Number: 174
not out im looking on 7 other sits for 289t will post if i can find it
Username: Crazy_greek
Post Number: 497
As of now ,no where to be found.
Username: Canndy
Www.livefta.com, Www.livefta.com Www.livefta.com
Post Number: 159
Not out yet.... [link removed] always latest files.
Username: Biverland
Post Number: 78
289T ..................
Username: Senators
Post Number: 71
it will come out soon so plz wait for it
Username: Brucester
Post Number: 176
do you think we have a choice
Username: Ars88
P.I.M.P , Pakistani/In...
Post Number: 390
lol bruce..ya i really want that bin to come out
Username: Biverland
Post Number: 79
Is there 289T ????
Username: Ke5aqn
Shawnee, OK USA
Post Number: 607
As of now I just looked at several sites NO clone safe bin yet...We will start a new thread when it is out.....
Username: Ke5aqn
Shawnee, OK USA
Post Number: 608
Sorry I forgot this
To my shadow,
I feel I answered in the best way possible for this moment. I feel it unnecessary to explain in great detail a bin that is not for his receiver, how to load a file with a serial port and cord, or how to unzip a file. Thanks
Username: Brucester
Post Number: 179
i i captaine jay thanks for the info
Username: Nikk
Post Number: 1017
mbenz...
289T is not for clones, the "T" means it is for Tivo, for clones you need the "t" file normally coming from chancy.......you can fry your receiver, be careful....
Username: Letmeon
Post Number: 127
I have always used the "T" bins on my Pantec Ultra with no problems !!
The bins without ANY letter T or t are unsafe for clones !!!! Only with T or t bins are clone safe..
Post Number: 499
Chancysand "T" Bins Explained.
The "T" in the file names means
that they are MODED by me and THAT
is ALL it MEANS.
CHANCY
Username: Budgie123
Post Number: 10
Guess this time bl changed the way he put the killer code in the bin, thus takes a while for Chancysand to find, test and remove them.
Username: Lklives
Post Number: 7331
I will explain this for the LAST time...
Chancysand make "T bins (upper case "T" since last March) and uses Blacklist (BL) same file, except modifies them and renames them with the "T" after the bin #...actually upper or lower case "T" is irrelevant...
Chancy's "T " bins are designated "T" for 1 reason ONLY., T = Tivo!
Chancy;'s 2500 bins (x-85BL) which are modified genuine Pansat 2500 bins created by Blacklist, are NOT ONLY modified for Tivo, but ARE also modified for Pansat 2500 CLONES and Fortec Ultra's,.. he believes Fortec is the original receiver, and the Pansat's are CLONES of the Fortec (BTW...he is 100% correct) back then..that is the ONLY reason he modifies the BL Pansat 2500 bins to accept the Fortec Ultra, which is very similiar to the Pansat 2500, and identical to Pansat 2500 CLONE receivers..
Chancy also modifies 2700 and 3500 Pansat bins and adds, the "T" after their bin #'s, BUT those are NOT clone safe...and are ONLY TIVO modified...
Username: Hicham
Post Number: 56
hi guys, any news for the 289 safe clone?
Username: Tupas1
hi guys need help to over come error write fail ER1 error i am getting when write 288T.
Username: Tupas1
some one can help me with "Write Fail ER1" error getting when trying to write bin file 288T on fortec lifetime ultra receiver.
Username: Dishlover
Toronto, Ontario Canad
Post Number: 29
Hi Guys
Any idea if 288T is working fine and safe for oansat colone? and doest it bring back all missing channels?
Thanks
Username: Dishlover
Post Number: 30
Hi Guys,
Need help to know if 288T is safe and bring back all missing channels for clone pansat 2500a. Thanks
Username: Nydas
Post Number: 1473
288T will bring back ZEETV, ZCINE, SET, SETMX, B4U, etc.
There are occasional freezes and and resets. The autoroll does not work at installation, so you will have to manually install the keys.
It works with some gliotches.
289T is expected any time and it does correct these glitches.
Username: Dishlover
Post Number: 31
Thanks Nalin You are star. I'll wait for 289T to come out. Your explaination is appreciated. Any Idea when is the possibility of 289T.
Username: Canndy
Post Number: 166
[link removed] - 289T
Username: Prfrmnj
Post Number: 1699
Chancy just posted bin 289T about 40 minutes ago at www.al7bar. tk
Make sure you remove the space between the period and the "tk".
Username: Brucester
Post Number: 185
thanks for the info
Username: Biverland
Post Number: 80
The 289T from chancysand WORKS OK
Autorolled Dave & Bev ....
much less problems then 288T bin .....Upload
Username: Brucester
Post Number: 186
is your epg working no big deal for me but the last bin had good
epg go figure
Username: Brucester
Post Number: 187
it is working now but not as good as bin 288 but it had its own big problems all is good sorry
Username: Nydas
Post Number: 1484
X-85BL_070125_289T_db_api(N).bin by chancysand
Moded for Hughes / Tivo ir codes. Good for ALL Pansat 2500 and clones and for Fortec Lifetime Ultra.!
Get Serial Load Here:
[link removed]
Get Full Jtag File Here:
[link removed]
Username: Dishlover
Post Number: 32
289T is working good. Just uploaded and got all channels back. Thank God.
Username: Biverland
Post Number: 81
NO FREEZING...........NO REBOOT ..
Over 3hr no problem at OLL
THE 289T from chancysand is OK...UploadUpload
Username: Zibruno
Post Number: 18
how come the 289t bin has full jtag after api?
could that be the problem why i can't download it
Username: Prfrmnj
Post Number: 1718
Home boy - You only use the Jtag bin if you had to do a JTag to your receiver. Otherwise just download the regular 289T
Username: Zibruno
Post Number: 19
but where do i get the regular 289t prfrmnj
Username: Lklives
Post Number: 7366
all sites have the 289T bin for Pansat 2500 clones and fortec Ultra's...use ANY site posted in the REPUTABLE DSS SITES thread..
Username: Lklives
Post Number: 7367
All these sites ALWAYS have the latest files, bins, how to's, manuals, guides, dish pointing calulators and tips, hardware info, jtag info, newbie and getting started sections, actively moderated with a no troublemakers and no bashing allowed policy.. and are free, and only require a simple free registration...Your email info is kept private, unless U specify differently..and U will be notified via email of any replies to any questions U may ask (or U can shut that feature off, if U like)..and your IP is sacred and never released..
Some of these specialize in particular FTA receivers as noted next to their links..
If U want real info, trouble free, no costs, friendly help, no hassles, latest files and manuals, then use these...these are well established, and have a long history, and are the best known sites throughout the entire DSS community for many years now...
Ecoustics is NOT a Dss site, since is has NO files, no manuals, no guides, little info, no specific categories, and is almost impossible to find anything because every thread here has been allowed to be hijacked (because no mods are active) and the Subject does not relate to the posts within it....also Ecoustics is basically an Electronics site for home audio, television, DVDs, stereo's, and things of that nature, NOT FTA satellite information
So again I highly recommend using ANY of these sites in this first post!....U pick one and use it for fast , friendly info and files, and many of these also have a LIVE chat area what U can get an IMMEDIATE response from a reliable knowlegeable sources!...U will save yourself much time, especially if you are a newbie to this hobby!...and most all also will have the latest keys posted as well, and the keymaster, keyripper, key grabber utility files to download as well....and if plastic is your thing , some also have an area for that as well as FTA..Good Luck and enjoy this hobby!
Final Solution Free To Air:
[link removed] (C00LSAT and All receivers)
DSS Newbies:
[link removed] (Pantecs,all clones and all receivers)
[link removed]
Username: Nydas
Post Number: 1520
X-85BL_070125_289T_db_api(N).bin by Chancysand
Moded for Hughes / Tivo ir codes. Good for ALL ! Enjoy !
[link removed]
