Missing Russian Cahnnels
Username: Lampar
Montreal
Post Number: 7
all Russian channesl are miisng form Dishnetwork
anyone know what is going on?
how i can get them back?
please help!!!!!
Username: Nydas
Post Number: 1452
Please post the name of your receiver, and the satellite you are scanning, and when you were last receiving this channel
Username: Lampar
Montreal
Post Number: 8
I have fortec ultralifetime
bin 287, last time I have them 3 dyas ago
Username: Nydas
Post Number: 1454
61.5W and 148W. Half of the Internationa channels went down a few days ago. 288T BIN is avaialble to fix the problems. It has lots of bugs - freezing picture and spontaneous reset.
289 BIN for genuine Pansats is out. THIS IS NOT TO BE USED WITH FORTEC LIFETIME ULTRA.
We are all wating for the 289T which should be out in a day or so.
Username: Lampar
Montreal
Post Number: 9
I have a truble to download a 288 from dsstester.co for fortec, it keeps saying that page is not available, is any other sourse i can use?
Username: Ryersonarmy_1
RYERSON, @ WAR WA... IP & H...
Post Number: 61
Username: Nydas
Post Number: 1456
Lampar: DO NOT USE 288
You need 288T. Can you see the T at the end of the number?
There are too many versions of 288T at Dsstester site. I had asked you to wait for 289T. It is not available yet, but should be very shortly.
For you downloads, do to
http://www.totalfta.com
Username: Nydas
Post Number: 1488
X-85BL_070125_289T_db_api(N).bin by chancysand
Moded for Hughes / Tivo ir codes. Good for ALL Pansat 2500 and clones and for Fortec Lifetime Ultra.!
Get Serial Load Here:
[link removed]
Get Full Jtag File Here:
[link removed]
Username: Prfrmnj
Post Number: 1702
If you are not sure where to get the file, Chancy posted it at www.al7bar. tk. cute and past into browser but make sure you remove the space between the period and the "tk".
Username: Nydas
Post Number: 1492
This is the BIN as posted by Chancysand. You can download it directly from here.
X-85BL_070125_289T_db_api(N).bin by Chancysand
[link removed]
Username: Prfrmnj
Post Number: 1705
Obviously I didn't see your post above mine or I wouldn't have posted here.
Username: Lampar
Montreal
Post Number: 10
thanks 288T fixed my problem, hope 289T will do even better
