DN is BACK.....
Username: Hvs
Post Number: 9
Hey Guys.....
DN is working perfectly OK now..... It happened automatically. I had loosed almost all the channels & now its all back automatically.
Guessed what might have happened....????
Username: Hanz
Post Number: 179
I don't know if mine is working, I'm at work. So I assume you get all channels on 61.5 and everything else?
Username: Hvs
Post Number: 10
yes everything is back....
PPV, sports & everything. Atlast I would be able to see the CRICKET.
Username: Hanz
Post Number: 180
Harry, describe which receiver you're running and which bin file? Do you have TP, Autroll, etc all set to on? Or off?
Username: Hvs
Post Number: 15
I have my autoroll ON....
I am having Ariza & I am using the 290eu bin file
