Help... $ appearing in front of channels, Cant get to CAS System Menu
Username: Cabrunet
I'm progressing, even tho this is getting on my nerves. I have a good signal and only get 1 working channel GOAL TV...Spanish Soccer! All my other channels have a dollar sign in front of them and say scrambled. I have a Pansat 3500 SD and a DishPro 500
If anyone can help, i'd appreciate it. my email is cabrunet@aol.com
Username: Ke5aqn
Shawnee, OK USA
Post Number: 277
the $ just means its a scrambled channel. Almost all channels on Dih Network or BEV will have that. All you need to do is make sure your key's are updated with the latest. I just posted a thread here a hour or so ago with the working keys.
if you need help just ask I have a working pansat 3500
Username: Cabrunet
Post Number: 7
Jay, thnx for the quick reply. I was told I have to get into the parental controls to set the keys, from there i can enter oooo and get a new screen, cas screen or something, that doesnt happen for us. Any more help? Thnx.
Username: Ke5aqn
Shawnee, OK USA
Post Number: 278
Heres how to updat the key's on your pansat 3500SD
Menu button
select Parental Controls
2nd PIN/enter 0000
Nagravision
Select dishnetwork (top right, use r/l arrows)
scroll down
select key 0
scroll down
enter the new keys (the letter keys are shown on the screen by function key). Check them carefully.
scroll up
select key 1
enter the new keys (same letter keys as above - bottom of screen). Check them carefully.
Hit and hold OK until it flashes (red, bottom right) on the screen.
exit out and watch TV
only thing I want to add is be sure and Hit and hold OK until it flashes (red, bottom right) on the screen several times while putting in keys. Also after you put keys in both lines read them to be sure you got it right just one # off and it wont work.
Username: Ke5aqn
Shawnee, OK USA
Post Number: 279
To get to the keys go to parent control and go DOWN to second one and just put in 0000 its easer than it looks. It got me too at first.
Username: Ke5aqn
Shawnee, OK USA
Post Number: 280
also here you will find all the info you need on that receiver. How to's, bin's, how to fix problems easy, everthing you need.
Username: Cabrunet
Post Number: 8
While i am still without a solution, I finally came to the conclusion that i am actually supposed to see the words SECOND PIN on the screen...and I don't.
Username: Ke5aqn
Shawnee, OK USA
Post Number: 286
ok hang on I was on fark.com surfing the funny phoshop pic's
Username: Ke5aqn
Shawnee, OK USA
Post Number: 287
ok here some screen shots I just made with my digital cam for ya
first click on parental control like here
Then go down once to the words second pin and mash your 0 four times.
then you will see this screen go down to nagravision 2
then put in your key's
now watch TV !
Username: Ke5aqn
Shawnee, OK USA
Post Number: 297
You might want to also try the master pin its ether 1668, or 1010.
Let us know how its going..
Username: Cabrunet
Los Angeles, CA USA
Post Number: 9
I want to thank you for your help. I don't know what I did, but I GIVE UP. Today all I get on the TV is snow, and the pansat remote doesn't let me do anything. It's not the batteries. =(
Username: Cabrunet
Los Angeles, CA USA
Post Number: 10
Thank you for all your help. I think now i really fowled it up. I get nothing but snow on the tv and can't reset the pansat. The remote works ...it turns on my vcr, but it doesn't clear the tv. Its stuck on b70 and the tv screen has snow.
Username: Ke5aqn
Shawnee, OK USA
Post Number: 299
did you push the stb button on the remote? It tells the remote to control the receiver. Also can you turn on the receiver with the buttons on the receiver? get to the channels with those buttons?
Username: Cabrunet
Los Angeles, CA USA
Post Number: 11
KE5AQN IS A MIRACLE WORKER!!!! We got TV thanks to him! While everyone was so helpful, KE5AQN was able to trouble shoot , walk us thru, fix our problems and get us TV. KE,my husband and I appreicate your knowledge, your determination and most of all your patience! We don't know how we can ever repay you!!!!!!!!!!
Username: Ke5aqn
Shawnee, OK USA
Post Number: 310
well you are very nice people it was my pleasure you are very welcome..
