Pansat3500s clone need help
Username: Joint
I'm looking for info on a loader and a binfile for my pansat3500s, any help will do
Username: Prfrmnj
Post Number: 1328
Is this a clone? You need to go to Future-FTA (pansat home site) register and you'll find loaders files and how to manuals.
Username: Ke5aqn
Shawnee, OK USA
Post Number: 306
Future-FTA is the home ofr pansat all you need to fix it is their.
Username: Joint
I have Pansat3500-x-05bl loader v3.40 [x-05bl] and Pansat3500-x-05bl -070104 B80-306-api. does anyone know if these would work on this clone ,do i have to load a older bin file first , plus i'm using a null modem cable will this work for me?
Username: Joint
I have one dead 2700 ,i want to do this one right
Username: Ke5aqn
Shawnee, OK USA
Post Number: 308
All the info is at www.future-fta.info.
Hope that helps
Username: Senators
Post Number: 63
u must make sure u get a clone safe bin
also u need to update ur boot file to boot 80.
go to this site:
www.future-fta.info does not have have clone safe file. u will just kill ur reciver
Username: Prfrmnj
Post Number: 1329
Do yourself a favor and get the bin from a reputable site. Go to this link and pick any one site, register and then look for the clone safe bin.
https://www.ecoustics.com/electronics/forum/home-video/309505.html
They are reputable for a reason. Then again, it's your box. You can listed to:
wing
Username: Senators
Post Number: 63
Or follow the advise of:
PRFRMNJ
Username: Prfrmnj
Post Number: 1328
It's your money not mine!
Username: Senators
Post Number: 64
well i thing i am right becase i have a pansat clone 3500 and i know what i am doing.
Username: Prfrmnj
Post Number: 1332
I'm glad you thing (by the way spelled THINK) you know what you are doing! I own more stb's then you can imagne the 3500 being one of them and unlike most here, I'm actually in the testing of equipment and not only for the free tv.
As I said, it's not my money. Just make sure when the po-po comes after him or his machine goes down for good, you are there to respond.
Username: Senators
Post Number: 65
www.future-fta.info does not have have clone safe file. i just checked
prove me wrong if you are so good.
Username: Prfrmnj
Post Number: 1334
And exactly how did you do that since Future-FTA has been down for some time. Dude, you are barking up the wrong tree.
As I said in my previous post to George
George:
Username: Senators
Post Number: 66
o.k man thx for the info
