Cable Hacking
Username: Asharfi
Post Number: 472
Cable Theft The Neighborly Way
You will need:
Underground Cable Source
Neighbor
2 Way Signal Spliter
1 Foot Of 75ohm Coax Cable
A Cable Ready T.V.
Basic Cable Subscription For A Month
1. Order cable for 1 month...This way they will bury the cable in your yard,
saving you a lot of work...
2. After your one month cable subscription is up and they have come and taken
your box, go out to your cable box and hook the end of the wire that goes to
your house to one of the outputs on the signal splitter...
3. Disconnect the wire going to your neighbors house from the cable source and
connect to the other output on the signal splitter...
4. Now hook the 1 foot section of wire between the input on your splitter and
where your neighbors wire was connected to the cable source...
5. Now go in the house and hook the end of the wire that was hooked to your
inside cable box to the coax fitting on the back of your T.V..
6. Turn your T.V. on,you should now have whatever cable your neighbors have...
If you know any TV hacking like this, please post it here.
Username: Ke5aqn
Shawnee, OK USA
Post Number: 260
This is off topic here. We all get digital satellite TV why would we want analog cable?
Username: Jojogun
Fairfield, CA United States
Post Number: 253
From what I gather, with this setup you don't have a choice of what to watch. You have to watch whatever your neighbor watches. That sucks.
Username: Joed
Post Number: 10
And the first time the cable comes back to the box and finds the splitter your screwed.
Username: Asharfi
Post Number: 473
My BAAAAAD...
THIS THREAD IS CLOSED!
LOOOOOOOOOOOOOOOOOOOOL
Username: Satscanner
Beaversbush, Sportsmans P... Great White ...
Post Number: 792
I have heard this is way in my area,hehehe.When The cable company terminiates your connection at the box they install a round cylindrical terminator that prevents signal leakage and terminates the connection.First you remove and modify the cylinder pulling the guts out by the wire,thinks is it's diode inside but doesn't matter,then drill a 1/16 hole through it,then insert a previasly removed centre wire from your rg6 coax through it.with a model paint brush put a quick drying epoxy/glue inside to secure the the new bypass wire.then reinstall the now "fake" terminator and reconnect the coax the way it was oringinally.This way when the cable company inspects the connection it looks as if it's terminated but the anolog signal is being connected.the cylindrical terminator always has your cable connected to it even when terminated ,without this device they now rhight away its a illegal hookup.When digital internet is supplied to the house without cable tv,they install a hugr filter to block the anolog freq.This can also be done to that too.Because the signal is sheilded there is normal/minimal signal leakage to be detected.I know personally peopple who are, and have done this workaround for quite along time.
Post Number: 793
If I had my camera I would show you pictures on this proceedure.
Username: Ke5aqn
Shawnee, OK USA
Post Number: 284
ya we need to see them
Username: Ryersonresurrected
CANADA Charlatan...
Post Number: 575
This is not goooood......i have the box in my backyard. But they've (Cable Company Contract Guys) come over several times asking me if i've seen anyone tampering with it.
I never have. But he told me that several of the neighbours were receiving free cable, and that they had already been warned before.
They then submit a report 2 hand in for prosecution consideration.
A few years ago, i was working between 2 cities...had free cable, supplied by condo, in Toronto, and decided 2 terminate the other one (my home) outside the city.
The only filter they left was on the house wall, so i just kept taking it off when i came to that home on some weekends, and replacing it when i left back 2 toronto.
One weekend..one...ONE... and i mean ONCE i forgot 2 put it back. Gosh, I always have my phone line forwarded 2 my cell - I got a call in toronto:
Hi, I'm calling from the ____ cable company
-yes
How are u enjoying ur cable television? Any trouble with it?
-i'm ok with it..it's fine.
So ur admitting u are watching cable television?
--yes...i am, what's the problem? Why are u calling me, i'm rather busy.
yes, the problem is ur not paying for it.
-- umm, of course not. So what? Am i suppose 2 be?
Well, that is against the law to tamper with the cable line. We had terminated ur service and placed filters at ur house.
--HOUSE! oh....... what house? i get cable for free here in toronto, is that what ur asking about, i'm confused....hmmm
no sir, What do u mean ur in toronto? what? are u not at ----- address?
-no! i live in a condo in toronto, haven't been at that house in months. Is everything ok over there?
Well, someone reported that ur cable had been tampered with....
Umm, maybe the kids in the area. But no one lives there - OMG IS MY PLACE OK!?
Yes sir, ummm....well then....we'll figure this out...sorry 2 have disturbed u.
OMG! ok...
thanks for ur time, sir
ok ok ok
good bye
bye
sigh - eeh eeh......
Post Number: 796
But Ryerson,there was no filter in place when they looked,that why you got caught.Always leave the dummy/modded filter there.They always leave the coax connected so moisture does'nt get into the coax.Since they went digital,all and require set top boxes,they always either have the anolog filter or the terminator in the connection.Thats why it has to be bypassed but look untampered with.
CANADA Charlatan...
Post Number: 578
Yeah, i know, i messed up and should have put it back.
But now i don't want 2 give them any reason 2 bother me....
My neighbour told me that around that time, different cable guys were at my place almost weekly 2 check and recheck.....so, i better not even try it......
Anyway, who needs it? I'm getting what i want when i'm home now with FTA ......
i kind of wish they would offer some package that would be dependent on usage..... 'cause someimes i don't use my internet or tv for months at a time, then i would actually consider some basic package.
Post Number: 802
Yeah, like pick and choose only the channels you want.Not what they want to sell you.But now with all the new technollagy,internet ect,their going to have change something.I think of cable as a dinosuar,always tethered and obsolete,At the beginning of automobile revolution,there was somebody making the best buggy whips ever,but nobody wanted them.
Post Number: 803
I still have my old brown zenith anolog hacked cable boxes.But i don't understand why the new digital system hasn't been hacked yet.or if it has not public.Theres got to be way,but always being tethered by a cable makes it difficult.
Username: Tapeman
Post Number: 397
Scanner
It will be
Be patient they will get it both ways like double jeopardy
One as hac#ked receiver via cable
Second as FTA via Ku Band from their Satellites
PoweVu is the access code to be cra#cked
There is more people hate cable than any satellite available today
At the moment who needs any more than both DN and BE#V
As easy as 123 from one receiver and 2 sm dishes
DTV st choice and cable that is the little stuff
We can prey on those as we get finally denied from major meals
Post Number: 809
Yeah, and this time Payback is for real! lol.Did you see the cbc tv show about the david and goliath,the "underdog"?It was a bout bev Telus ,and other big corps putting the screws on the little end user customer.They make mistakes in billing and services,then demand big payments and then send to collection agency destroying your credit,when its their mistake! FAK!And theirs nothing you can do to get it straighten out.Think it's called EXTORTION.
Username: Prfrmnj
Post Number: 1359
I've always said "There is no reason we should be paying for TV" Advertisement pays for them anyway, so why should they be dual compensated?
CANADA Charlatan...
Post Number: 585
Don't be silly, How would Ted Rogers and Rupert Murdoch ever afford a proper meal?
Post Number: 815
Speaking of the devil his red van just pulled up to their box out front,....hmmm...The neighbourhood kids should burn that box rather than spraypaint graffitti on it.lol
Post Number: 816
"The devil in the Red Van"LMAO
