Bruce l cw600 s pre kround
Username: Larrydumass
Stuppitville, Ark Werdufunkarewe
Post Number: 26
do i have load the factory bin cw600s premo or can i just load kround then the 130 bin
Username: Brucester
Post Number: 137
C/P
DO NOT use the CX-Loader 2.50 bin file on the CW600 Premium box
It will damage your unit.
CW600s Premium S/W Upgrade Guide!
By mrokarvi
Tools Need to update your receiver CW600s Premium Receiver:
1- Null Modem Cable
2- Newest bin Patch "CX_Kround_600Perminum_V1.XX_date.zip" Make sure it is for Premium model.
3- Loading Software "Loader v1.05.zip"
Create a folder on you PCs desktop name "CW_Premium" using Winzip or Winrar unziping program to unzip all files to "CW_Premium" folder.
1) Connect your PC and receiver with twisted RS-232C Null modem cable.
2) Power off the receiver from the back switch.
3) You can load bin file using two methods "boot" Mod and "Standby" Mod. If you want to load the sofware using "Standby" Mod go to #4.
Here how you get into "boot"MOD:
Hold power button on the front of the receiver and turn the power ON from the back of the receiver. You will see a word "boot" on the front LCD screen of the receiver.
4) Turn receiver Off from the back and then ON the receiver; you will see 00:00 now press "POWER" key on front of the receiver panel to make it standby, the LED dot will display "- - : - -".
5) Start New LoaderV1.05.exe check if the right COM port is selected then select
<download>, press <open> and select the bin file,"CX_Kround_600Perminum_V1.XX_date.bin" then click <start>, upgrade will begin.
6) After finishing, the receiver LED will display "-End"
If your experience any problem during the upgrade start over again.
For All of the Featuers available in CW600s Premium Model Please click on this Link :
CW600 New OSD Features Guide (This part works on CW600S & CW600 Premium)
http://www.dssrookie.com/forums/img-...ide-72921.html
hope this helps you
Post Number: 27
u d da man word up thanks
