install bin Pansat 2500 clone 286T with BL updater v 1.4...then it has autoroll bin which willupload new keys...or do Pansat method then on manully input keys..
1. Push menu 2. Select parental control and hit ok 3. Select second PIN and enter password 4. Select Nagravision 2 and hit ok 5. Select Provider ID by pushing right arrow(DN should be first) 6. Go to key number to select the key you want to change. 7. Enter keys 8. When you need to enter a letter, use the guide at the bottom of the screen. For example if you want to enter the letter A you need to push the Audio button. 9. After all keys have been entered push ok to save. 10. If you need to enter another set of keys just repeat steps 6-9 11. When done exit out until you are back to the tv screen.
actually my post is for james...use bin 286T with autoroll..or manually inut keys like a Pansat receiver...there are NO other working bins for the Fortec Ultra...
thanks alot guys, i got into the section where iwanted to go, i am still not getting any picture maybe i did something wrong. the key # I installed were BF F0 F3 13 D0 E3 74 E6 0E 03 1A 7E A3 EE 73 E3, ARE THESE CURRENT???? THANKS AGAIN FOR ALL YOUR HELP
my setup doesn't show as key 0 & key 1; I have: Provider ID (set at) 01 01 Key Number (set at) 01 key Data (set at) BF F0 F3 13 D0 E3 74 E6 0E 03 1A 7E A3 EE 73 E3
james 1 more thing you have to turn the autoroll off to see if it work...i have no idea where to turn it off..because i don't use lifetime ultra..after you turn the autoroll off but still no TV..then turn your box off from the back of your box,than turn it back on..see if it work...that all i can help..good luck.
